Go Back   HeliFreak > R/C Helicopter Support > Miniature Aircraft Helicopters > MA Gas
MA Gas Miniature Aircraft Gas Helicopter Support Forum
Old 03-02-2011, 09:07 PM   #1
baseclass
Default New Spectra-G...
Finally got everything together... TRM motor, Raja's generator, electronics.....
I'm gathering the courage to open the first bag and then start fuming because I don't see the pull starter in any of the bags.... Then I realized it's attached the engine..
Yes I'm nervous! haha...
baseclass is offline        Reply With Quote
Old 03-02-2011, 09:57 PM   #2
rbort
Default Search for the 2mm washer in the kit taped to a piece of paper
Its supposed to be installed on the bottom of the engine before the dogbone starter for the pull start. You need to unscrew that piece, put the washer on, and screw it back on with some blue locktite.
Some people forget that piece, or try to install the nut instead below the dogbone.... The nut is to be used for electric start only (with no pullstart dogbone), which is not the case for you since you have the Jewel. Just the washer before to install the engine to the frame.
Good luck and enjoy the build!
-=>Raja.
Raptor 90, Hanson 300, 267 flights
MA 1005, Hanson 280, 4060 flights, Spectra-g, Hanson 270, 3140 flights
Whiplash-g V1, Hanson 270, 1328 flights, Whiplash-g V2, Hanson 300, 45 flights
Jewel on-board Generators, Miniature Aircraft Team Manager
rbort is offline        Reply With Quote
Old 03-03-2011, 12:05 AM   #3
baseclass
Default Pull start, et. al.
Yes - thanks Raja.
Looks like MA is sending out a different washer now as well along with an updated instruction for install.
Also posted on another thread but I've already found missing pieces. Two 0067 M3x14 bolts for the bottom of the head are missing from bag 1B. Looks like at least one other person had the same problem. I can probably find them at the local hardware store but still, kinda stinks.
k
Old 03-03-2011, 10:06 AM   #4
rbort
Default Don't sweat it too much
Build the entire kit, make a list of what is missing and I'm 100% sure MA will send them to you to complete your kit.
-=>Raja.
Old 03-04-2011, 12:38 PM   #5
Joe Bailey
+100 on that. no doubts at all, my kit was missing alot of m3x10 bolts, stole some from an rc car to finnish and the missing stuff was promptly sent out free of charge.
Joe
I'm not controlling it, I'm just preventing it from crashing.
Joe Bailey is offline        Reply With Quote
