Old 03-16-2011, 08:25 AM   #41
lyco46
2.03 Lost facial hair
lyco46 is offline        Reply With Quote
Old 03-16-2011, 08:30 AM   #42
lyco46
Old 03-17-2011, 08:59 PM   #43
Ampdraw
Nice flying lyco.
Good to see an Aus performance vid too in a teeny space.
Amp
Ampdraw is offline        Reply With Quote
Old 03-17-2011, 10:01 PM   #44
RĒzĒ
Tight squeeze:
RĒzĒ is offline        Reply With Quote
Old 03-17-2011, 10:15 PM   #45
lyco46
cheers...you gotta love a tight space....
only way to learn...I fly my 90 in there, when i'm not too..
Old 03-17-2011, 10:18 PM   #46
Mojappa
Nice!
Compass Atom 5.5: AR7200BX, Talon 90
Compass Warp 360: AR7200BX, Lynx Blades
Mojappa is offline        Reply With Quote
Old 03-17-2011, 10:20 PM   #47
tracknoob
Originally Posted by RĒzĒ View Post
Tight squeeze:
I love it! As much up=down 'bobble' as these things have, one has to wonder if a running start wouldn't be a bit easier.... in any event, ya shore 'got 'er dun!"
tracknoob is offline        Reply With Quote
Old 03-17-2011, 10:22 PM   #48
PittJitsu
Tight squeeze:
Great flying!
PittJitsu is offline        Reply With Quote
Old 03-17-2011, 10:24 PM   #49
mediclavina
Originally Posted by lyco46 View Post
I like the tight flipping capability of your mCP-X. What pitch and cyclic end-point values are you using on yours?
GAUI EP-200 V2 FBL, Blade Nano CPX, Blade mCP-X, Hirobo SRB Quark, Blade mSR, Blade mCX
mediclavina is offline        Reply With Quote
Old 03-17-2011, 10:33 PM   #50
tracknoob
Awesome. Make a bookmark of this vid (minus the crash heh heh) for anyone who doubts it can be flipped in a small vertical space.
(Oh and be prepared for the conspiracy theorists ratting you out for your obvious use of custom made lipos and top sekrit skunkworks brushless motor...)
Watching that pore ol' mcpx get thrashed (in a good way!) makes me feel a bit for the whole fleet of them out there getting smacked into walls, ceilings, concrete, etc all over the planet right about now....
Old 03-17-2011, 10:46 PM   #51
tntburnett
Default Here is my flight and how to set your pitch
Just a lil fun with the great heli. And to show that it do what it suppose to do. God is Great
tntburnett is online now        Reply With Quote
Old 03-17-2011, 11:20 PM   #52
tracknoob
Well, it actually happened -- I provided a pointer to your vid as evidence this little heli really can flip in a tight space, and it looks like some folks are inclined to assume it takes hopped up batteries, motors, etc.
Now, there is nothing wrong with that if that's what it takes, but I'm not sure that yours has been hopped up.
Would you mind telling us if you've done any mods, or is that really out of the box performance, with only whatever set up you did to radio and adjustments to heli?
Thanks for providing the vid, and for considering sharing any tips you might have for the frustrated would be stunters out here...
Old 03-18-2011, 01:23 AM   #53
lyco46
Hey how goes it
That video was made with stock batteries, only difference is the see saw bearings from the trex 250...everything else on it is stock.
Only got the hyperion batteries yesterday.
Happiness is directly proportional to a fully functioning heli....
Old 03-18-2011, 01:30 AM   #54
lyco46
100 % just stock settings no expo full rates i got sick of splitting tail shafts so used a 250 boom support u have to resolder the horrible connector so i just cut the wire in the middle and soldered (or sodered as finless says) in the middle
now when it splits i just have to replace the shaft 6 bucks for two cause the motor and wire are usually fine and I just rerouted the cable to the outside with heat shrink
I also extended the tail shaft by 10 mm doesnt blow out as much and put 250 see saw bearings (stock are shit) in blade grips (use a tweezers inserted into hole and let tension hold the bearing and just squeeze to let drop in place ) with balls facing out, they bind otherwise
u have to be really mindfull of your collective with this little beast u cant punch out, head speed just dies i also put on hyperion 320 mah u need to modify the undercarriage i used velcro and i soldered in parralell the hyp connector with original so i can use both hyperion and original batteries
just swop undercarriage when using eflite batteries as had to cut away tray for hyperion
getting 5 min out of them in idle up 1, with 30% left in the tank and only 2 grams heavier but i've noticed with this heli the brightness of the batteries or motor dies after a minute and half tops so i do all my hard 3d in that time and just funnels and piro circles in the last half of the battery, a lot harder to flip it around when its lost its brightness
dont use normal mode any more got sick of flipping over and forgetting i,m in mormal so i take off from the ground in idle up 1 with all my helis
must have done that 20 times
The video was made before i screwed around with it just the normal tail shaft and stock batteries....
Old 03-18-2011, 01:42 AM   #55
lyco46
I dont know if the extended tail does it any good i could be just imagining it but my theory is the further its out the more leverage it has but then again it has to travel a bigger arc to do the same amount of work so it probably just cancels itself out
Old 03-18-2011, 09:06 AM   #56
shock
Got of vid done
Nothing fancy, still learning how the machine handles. This was my 4th battery. mCPx waves goodbye at the end!
shock is offline        Reply With Quote
Old 03-18-2011, 10:12 AM   #57
tracknoob
[snips]
...no expo
... full rates
...250 boom support
... [removed] horrible [tail] connector... cut the wire... soldered... rerouted... to the outside with heat shrink
... extended tail shaft by 10 mm
...250 see saw bearings... in blade grips... balls facing out
... be really mindful of your collective
... hyperion 320 mah... had to cut away tray for hyperion
...only 2 grams heavier
...do all my hard 3d [in the first two minutes of batt]
...video was... just the normal tail shaft and stock batteries....
Excellent!
Thanks so much for responding.... something tells me that those changes might be just the ticket to get this guy 'being all that it an be'!
Old 03-18-2011, 09:47 PM   #58
ckim
Default ChrisH flying 3D in the AeroMicro Lobby
Not the best video quality, but some excellent flying by ChrisH.
Stock mCP X with green canopy.
ckim is offline        Reply With Quote
Old 03-18-2011, 11:30 PM   #59
psanchez
Went to buy some parts for my mCP X at LHS and saw this as I walked in!!!
Awesome flying!!!
psanchez is online now        Reply With Quote
Old 03-19-2011, 12:52 AM   #60
Jasmine2501
Location: In deep space, abandoned. Any crew? Negative.
Jazzy's Flight Deck:
Jasmine2501 is offline        Reply With Quote
