| BeastX FBL System BeastX FBL Flybarless System Software and Hardware Support |
I'm looking to install a BeastX in my 500 and would like to know the following:
Does anyone know if it would be possible to run DSMX with only the satellite(s) (IE no receiver) AND have the TM1000 telemetry unit broadcast telemetry back to the transmitter (DX8). Basically, I'd like to eliminate the receiver and keep my DSMX and Telemetry. My guess is that it can't be done, but would like to hear from others. Thanks all! Last edited by pitchandyaw; 03-07-2011 at 09:33 AM.. |
I've read here that DSMX satellites don't work with Microbeast, and I've also read they don't work with TotalG. You must keep the receiver to use DSMX. There are a few posts here already, and I saw one over on AMRC from Curtis where he explains a bit what is happening with the TotalG:
http://www.allmyrc.com/forums/9664-post8.html
-Chris |
Read here Of course, we are talking about direct connection between a DSMX satellite and the Microbeast. If you use a DSMX standard rx, no problem at all. You could force DSM2 protocol for a connection between the new DSMX satellite and the Microbeast: so it will work as well. Ciao, Egidio
GAUI addict: EP100 PRO, EP100 V1, EP200 V2 BeastX/satellite, EP255 BeastX/satellite. Now, TREX 250 SE BeastX/satellite as well. |
Thanks guys.
How about running in DSM2 mode? This sounds fine by itself, but i'm not sure about the integration of the TL1000 telemetry model without having the spektrum receiver. Does anyone know if the TM1000 can do its job without a spektrum receiver in the heli? |
I believe it can, based on this conversation Bert K had regarding using telemetry with the Vbar:
http://www.allmyrc.com/forums/r-c-he...telemetry.html
-Chris |
#6 |
I have on my GAUI 255 the DSM2 satellite only (with adapter) and the TM1000, both bound in DSM2 and they work fine.
The TM1000 takes only the power supply from the Microbeast (on SYS connector). My TX is a DX8 FW v.2.01. Ciao, Egidio
#7 |
The Spektrum telemetry modules can talk to the transmitter without having to be connected to the data port of a receiver. With that being said, you have to bind the telemetry module at the same time you bind the BeastX or other receiver that is not data port compatible. In other words, simply do a simultaneous bind (telemetry module & receiver). All the telemetry features will work with the exception of the data that is dependent on the receiver data port, such as lost frames and holds.
Hope this helps
Bert Kammerer To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#8 |
Thanks all, and thanks Bert!
...I'm off to order a beastx |
