Old 03-07-2011, 07:44 PM   #1
thatdude596
Default 400 swash leveling tool
What are you guys using besides your eyeball
thatdude596 is offline        Reply With Quote
Old 03-07-2011, 07:50 PM   #2
dbennettya
Free leveling tool:
Disable motor, put in ST-1, throttle midstick. Now fold the blades like your going to use the blade holder for storage. Line the blades up so they run parallel to each other and don't hit the flybar. If you are at zero pitch with the flybar level the blades should line up. Now slowly rotate the main shaft with the bottom gear. If the blades remain even all the way around congrats your swash is level. Adjust servo links as necessary to get the best you can.
Good Luck, Don
dbennettya is offline        Reply With Quote
Old 03-07-2011, 08:10 PM   #3
BL_Trackstar
I use a trex450 leveling tool. I am a newb, so the more perfect the easier the heli will be to controll. But, any 450 size tool will work. Check ebay.
BL_Trackstar is offline        Reply With Quote
Old 03-07-2011, 08:25 PM   #4
thatdude596
Thanks guys didnt know the trex 450 was the same
Old 03-07-2011, 08:30 PM   #5
Avidflyer
You can buy a swash leveling tool for less than 10 bucks. Precision is everything when it comes to a good set up.
Blade 400 Hughes 500 Scale
Align 450 ProV2 3GX V2.1 450 Sport FB aka "The Beater"
Raptor 50 V2 OS50SX-H "Ol Faithful"
Align 700N LE BeastX
Avidflyer is offline        Reply With Quote
Old 03-07-2011, 09:10 PM   #6
biglipzit
450 Pro leveling tool is made for a larger main shaft. Has to be any 450 that is not pro.
biglipzit is offline        Reply With Quote
Old 03-07-2011, 09:57 PM   #7
whoanelly
just buy one of these and make your life easy..
http://www.readyheli.com/LEVELER-T-R...g_p_34921.html
Quantity:
700LE : 105HZR AR7200BX JR8917 Multi gov , JR9503
600ESP : 100AMP Castle. Scorpion Motor . AMA #962896
400 Blade : Scorpion 2221-6 ,Castle ICE 50 Sonix Head and t
Align 450 pro V2 3G MKS DS95 MSR , 2 x MCPX (brushless C05 & HP05), Blade 130X.
whoanelly is offline        Reply With Quote
Old 03-07-2011, 10:12 PM   #8
thatdude596
Thanks guys again for the help
Old 03-08-2011, 07:16 PM   #9
NUMBA
Quantity:
Yep. This thing takes all the work out of it. Fantastic.
Blade 400 - HS-5065MG x3, HSG-5084, Futaba GY520, SportBEC | DX8
mCP X - Extended | DX8
NUMBA is offline        Reply With Quote
Old 03-08-2011, 07:29 PM   #10
Ride
I used a fake dollar coin I had from some sort of amusement park and drilled a hole in the middle, it was free
Ride is offline        Reply With Quote
Old 03-08-2011, 08:18 PM   #11
FR4-Pilot
HobbyKing sells them for like $3.
Swift NX 550 (x2) | Swift 16 550 | Mini-Titan E325 SE | Mini-Titan E325 Pro (x2) | Blade 400 | Quark SRB (x2) | Blade mSR | Blade mCX
FR4-Pilot is offline        Reply With Quote
Old 03-08-2011, 09:01 PM   #12
thatdude596
Thanks will be ordering from the king when i order a batt or two
Old 03-09-2011, 04:46 AM   #13
kavic5150
Post Not so fast
Is the leveling tool really necessary? My swash always leans a little left to compensate for the tail rotor pushing air right. Right? So the tool would only get you in the ballpark
Hoss X4e 6s, Gaui 550, Protos 500 12s, Losi Speed-T.
Save the flybar !!
kavic5150 is offline        Reply With Quote
Old 03-09-2011, 07:19 AM   #14
thatdude596
Swash should be level man. The tool is the most accurate way . Ballpark is your eye. Compensate with right aileron not a tilted swash
Old 03-09-2011, 10:18 AM   #15
whoanelly
Agreed ,,a level swash doesnt mean you wont have slight drift,but your blades will track dead nuts when you have a perfect mechanical setup. ..
Old 03-09-2011, 10:28 AM   #16
Flyguy45
+1 Spot on every time..I keep saying it but just to be boring again..,SETUP,SETUP, SETUP... I know sometimes it can be a pain..but think of it like this,
a) You'll learn from it...
b) You won't have to keep guessing and go from one suspect part to another
c) When you've done it..you'll have a decent flying heli
Blade 400, Hitec 65MGs, 500 Skids, DX6i Align Trex 450 Airwolf w/ retracts/Nav, 450 SEV2, ME 109 Warbird
Flyguy45 is offline        Reply With Quote
