Go Back   HeliFreak > R/C Helicopter Support > Avant RC - Mostro & Aurora
Avant RC - Mostro & Aurora Avant Mostro, Aurora, Electric eAurora, RigidCore Flybarless Head, Avant EFX and Avant FX Helicopter Support
Old 03-07-2011, 10:11 PM   #1
deepak
Question wobble
Folks
Have any of you experienced a wobble, much like a hula dancer, on your machine.
Cant figure out what it is. advice appreciated
D
deepak kirpalani
Deepak.g.kirpalani@gmail.com
deepak is offline        Reply With Quote
Old 03-07-2011, 10:16 PM   #2
kanglou
Check all 3 mainshaft bearings if they goes smooth?nothing in the head that is loose?
kanglou is offline        Reply With Quote
Old 03-07-2011, 10:17 PM   #3
deepak
Not that I can tell.
Everything seems smooth. Head tight on shaft .
Any other ideas
D
deepak kirpalani
Old 03-07-2011, 10:30 PM   #4
kanglou
Do you run mikado vbar on your machine?
Old 03-07-2011, 10:33 PM   #5
kanglou
well deepak i saw that you run vbar in the another thread.So how does the spektrum analyzer look like if you have run it?Maby you can lockate where the vibes are?
Maby you should check the TT?So the bearings gooes smooth and the TT is straigt?
Old 03-07-2011, 10:49 PM   #6
deepak
Hi
Will do the vibration analyzer tomorrow and post my findings
d
deepak kirpalani
Old 03-08-2011, 12:56 AM   #7
Daniel Jetschin
Hi
Whats your Rpm?
Team Compass; Optipower Europe; Graupner
Daniel Jetschin is offline        Reply With Quote
Old 03-08-2011, 07:40 AM   #8
Cletus
From your description of a "Hula Dancer" it suggests a slow, orbital, oscillation. Assuming normal head-speeds, anything in the head would result in a vibration associated with the head-speed and not the "Hula" thing. My thinking is the "Hula" may be an oscillation setup by the Vbar system as it tries to correct the aircraft's attitude. Look at the setup carefully, inspect the spec analyzer and what about auto trimming?
A helicopter in flight is a working demonstration of all the basic physical laws of the universe in action. Member: AMA 928457 - IRCHA 3449
Cletus is offline        Reply With Quote
Old 03-08-2011, 07:59 AM   #9
deepak
Morning.
Rotor rpm set to , 1800.1900.2000
does the hula at all 3 settings
D
deepak kirpalani
Old 03-08-2011, 08:01 AM   #10
deepak
Cletus
The auto trim was done prior to changing the head.
I did try to adjust the gains on the gyro to no effect. Have not had the chance to do the spectrum thing yet.
Hopefully today.
d
deepak kirpalani
Old 03-10-2011, 02:51 PM   #11
Cletus
Lower is sweeter
Old 03-11-2011, 11:01 AM   #12
Laurens
Are those QuickUK servo horns?
Logo 800/Jeti DS16
Laurens is offline        Reply With Quote
Old 03-11-2011, 11:20 AM   #13
deepak
Yes Laurens,
They are the 9.5mm ones.
Working out nicely
regards
d
deepak kirpalani
Old 03-11-2011, 04:06 PM   #14
united737pilot
Cletus: did you cut down your avant head and use the holes where the flybar carrier was?
united737pilot
united737pilot is offline        Reply With Quote
Old 03-11-2011, 04:38 PM   #15
Cletus
No, that’s a Custom Short-block I machined from billet for Deepak, to solve his "wobble" issues and gain him some increased cyclic agility.
Old 03-11-2011, 04:58 PM   #16
united737pilot
Wow. Very Nice!!!
Also, what blade grip arms are those?
united737pilot
Old 03-12-2011, 09:03 PM   #17
deepak
Hehe
Wobble and vibration gone!! Finally a vibe free heli.
Main shaft was not true and bearings were shot?
Finally. She's sweet.
deepak kirpalani
Old 03-13-2011, 06:06 AM   #18
Cletus
COOL! ....I've been a fan of SKF bearings for a long time! Use them almost exclusively in all the machinery at my factories.
Old 03-13-2011, 06:10 AM   #19
Laurens
Have you crashed the aurora before? Or where they bad from the beginning?
Logo 800/Jeti DS16
Old 03-13-2011, 09:20 AM   #20
deepak
Remember Laurens
This is the second main shaft which was not true. I believe the shafts and vibration combo helped destroy them.
I had no crashes but I did have the heli roll left before take off in the earlies twice. Cost me a spindle, main shaft and blades both times. After using zeal tape on the vbar sensor I got it to settle down and work like it should.
The short block is awesome. Flip and roll much tighter.
regards
D
deepak kirpalani
