Old 03-11-2011, 11:11 PM   #1
shadowreader
Default Lack of collective response around mid stick
I was just reading the post and watching the video on VRS where the MCPx descends all the way to the ground even after you bring the collective back up. I am experiencing this quite noticeably but also see it when ascending as it will continue to climb even after I bring the collective back down to stop the ascent. It seems that from about 35-70% on collective there is slow response from the heli but then it really jumps up or down when toward the extremes of the collective range. I have tried this with all of my pitch curves and throttle curves as recommended for the DX7 in the manual and it exists with all of them. It doesn't appear to be a throttle issue as I have one that is a flat 100% and it does it there too. I have run through my pitch range and the ptich seems to change smoothly throughout and the servos appear to be working fine. I also increased by travel on pitch to 100% each way to see if that would remove the issue but it has not. Any thoughts on this? It basically behaves as though there is a very wide deadband throughout the mid collective range.
shadowreader is offline        Reply With Quote
Old 03-11-2011, 11:14 PM   #2
Mojappa
You could replicate expo and make a S curve for the pitch curve where you lower position 2 and raise postition 4 to get more pitch sooner in the stick range.
THIS IS MY SIGNATURE. THERE ARE MANY LIKE IT BUT THIS ONE IS MINE.
Mojappa is offline        Reply With Quote
Old 03-11-2011, 11:16 PM   #3
Matt Nasca
My collective is very quick and touchy. I'm using a DX8 with 25 expo, 100% rates and had to adjust the sub trim to get the collective to mid pitch. Stock settings have very little positive and a ton of negative pitch.
GAUI NX7 - GAUI X7 - GAUI X5 - GAUI NX4 - GAUI GX4 - GAUI X4 II - GAUI X3 - GAUI X2 - All on VBar 5.3 Pro
Team GAUI USA / Empire Hobby / Scorpion Power Systems / Optipower Batteries / Cyclone Blades / Savox / YS Engines / VP PowerMaster / JR
Matt Nasca is offline        Reply With Quote
Old 03-11-2011, 11:17 PM   #4
akamullen
Yep, every heli I own that is 450 and smaller(walkera, rex 250) I use an s curve to liven up center stick collective. The larger machines don't need it, IMO to get a linear feel, you need an s curve on the micros.
to even out the collective, use the pitch servo atv's
AnythingHeli.com OWNER/ TEAM PILOT
GAUI X5 / X7 *
GOBLIN 380/500-x2/630/770 * Swinging SWITCH/RJX/RAIL & SAB Blades * Microbeast/IKON * Castle ESC's on all * DX18 *
akamullen is online now        Reply With Quote
Old 03-11-2011, 11:17 PM   #5
shadowreader
I can try that it just seems odd. I know it was doing this before I swapped out the bad bearings because I was troubleshooting that when the blade let loose. Thanks.
Vibe 50, Trex600ESP SK720, Protos SK360, Mini Protos Beastx
Trex 450SEV2 Beastx, Blade 400 upgrd x2, LAHeli Ricco x3
Trex250SE, Walkera 4G6, MCPx, MSR, Mini Titan, Raptor 30
Boomer Sooner!!!
Old 03-11-2011, 11:23 PM   #6
mediclavina
Interesting.
I will try that out and see how it affects the collective response around mid-stick.
GAUI EP-200 V2 FBL, Blade Nano CPX, Blade mCP-X, Hirobo SRB Quark, Blade mSR, Blade mCX
mediclavina is offline        Reply With Quote
Old 03-12-2011, 06:37 PM   #7
Brady Miceli
Default Sub-Trim to even things out...
I set my sub-trim pitch to 50 (DX7) and I'm very happy with the results.
When I'm flying this thing I just can't believe it. It feels incredibly locked in and agile.
Compass 7HV / 4525-520LE
Align 500EFL PRO DX8
Align 250SE FBL BX - Blade MCPX
Brady Miceli is offline        Reply With Quote
