Old 03-13-2011, 04:18 PM   #1
flyinghigh450
Smile My 6S 600E with Castle build
This is my first time building a power train setup so I hope all go's well.This is as far as I got.Need to finish mounting and plugging things in then program the ESC.I'll post more pics tonight and the maiden flight (video) if the weather is good ..
flyinghigh450 is online now        Reply With Quote
Old 03-13-2011, 04:59 PM   #2
kouasupra
That looks like a mamba monster motor. What's the KV on the motor?
kouasupra is offline        Reply With Quote
Old 03-13-2011, 05:46 PM   #3
flyinghigh450
Yup,its a 1500KV..
Old 03-13-2011, 06:09 PM   #4
iceman320
what headspeed are you gonna be running?
iceman320 is offline        Reply With Quote
Old 03-13-2011, 06:18 PM   #5
flyinghigh450
Around 2300 RPM'S ..This is right from the Castle site
The 17 Series motors feature high quality oversized bearings, sintered Neodymium magnets, superior electromagnetic design, and rigorous engineering control in our own factory.
The 1717-1500 has 2 flats milled on it. Flat to flat is 46mm. Off the flats the can diameter is 49.5mm. The 1717-1500 will work on the Align Trex 600 with motor mount mods (holes opened up for larger screws to fit holes in the motor).
Applications: Trex 600, 4mm bolts. Requires small mod to motor mount for 4mm bolts. 6mm output shaft. 14t pinion, 2250-2300 HS. Use with Phoenix Ice 100.
Scroll down to the 1717 1500KV motor http://www.castlecreations.com/promo...clearance.html
Old 03-13-2011, 06:51 PM   #6
Tisondm
Originally Posted by OnTheDeck View Post
Around 2300 RPM'S
2300 RPM on 600!
JR X9503
TREX 500 ESP FBL, Skookum SK720, Scorpion 3026-1600, 14T
CHP TREX 600 ESP FBL, SK720, 8S, Scorpion 4025-740, 13T, WR Bec
TREX 700E FBL, SK720, 12S, Scorpion Comm 130A ESC & 4035-500 , 12T, WR Bec
Tisondm is offline        Reply With Quote
Old 03-13-2011, 07:39 PM   #7
Cheetah62
Be afraid.... be very afraid.
H/S like that is rough on your head components, rough on your batteries....
TREX 600ESP, Outrage G5, mCPX, CX3
Phoenix Sim - Mastering flight one crash at a time.
Cheetah62 is offline        Reply With Quote
Old 03-13-2011, 07:49 PM   #8
flyinghigh450
Im not worried so please don't derail this thread Cheetah62,thanks..
Old 03-13-2011, 09:27 PM   #9
pril250
Received a PM to take off the Video I posted. Nice guy.
Blade400
pril250 is offline        Reply With Quote
Old 03-13-2011, 09:34 PM   #10
gr8taz nitro
looks like you got a good start on the install. Looking forward to seeing some video when you get it done.
If love is Blind, why is lingerie so popular?
gr8taz nitro is offline        Reply With Quote
Old 03-13-2011, 10:26 PM   #11
flyinghigh450
Thanks gr8taz nitro .I'll have it finished for sure tonight and i'll post pics.Still going to need help setting the esc up,can I copy your setting and maybe tell me how to set the headspeed?If I get everything setup tonight,i'll get video tomorrow .Thanks again ..
Old 03-13-2011, 10:58 PM   #12
Freeskiken
I have two of these motors. I have installed one on my TRex 600 CF with the KDE motor mount. I have to go back and reprogram my CC Phoenix Ice 100. I emailed Castle about how many poles are in this motor. This is the reply.
"These are 4 pole in-runner motors and I believe they will run best with 8-12 PWM and normal timing. I would try 8 PWM and then try 12 to see which gives lower temps and the best sound."
I have to set this yet. I am working on two TRex 600 CF, FBL VBar, 6S one with this motor and one with the Neu 1515H/2.5D-1650Kv. I will set the governer in the ESC to a set head speed. 1800 rpm, 1900rpm and 2000rpm.
Thanks Ken
Freeskiken is offline        Reply With Quote
Old 03-13-2011, 11:14 PM   #13
flyinghigh450
Yup,I got the same Email .What I think i'll need help with is setting up the gov because I never used one on a electric ..
Lon,
The 1717 will not work in a T-Rex 600 on 8s, it is a 6s motor. It is a 4 pole magnet, 12 slotted stator motor. Use 12 kHz for PWM rate and normal or low timing. Go to low timing only if the motor runs hot in your set up.
_____
Bernie Wolfard
Castle Creations
540 N Rogers Rd.
Olathe, KS 66062
913-390-6939 ext. 123
Old 03-13-2011, 11:18 PM   #14
Freeskiken
I will program mine and then I will post the settings. Thanks Ken
Old 03-14-2011, 02:35 AM   #15
flyinghigh450
Sounds good Ken .Im pretty much finished with mine,just need to program the ESC and plug the motor in ..
Old 03-14-2011, 07:23 PM   #16
Tisondm
I would shorten those battery and ESC wires as much as possible. Turn your packs around the other way. That much length will be hard on the caps of your ESC. Here's a pic of my setup.
JR X9503
Old 03-14-2011, 07:42 PM   #17
flyinghigh450
Tisondm
I plan on changing it and cleaning the wires up but I wanna get everything setup first and do my maiden,I work backwards I guess .Your's is nice and clean,im not that good with wireing .
I have everything setup but have a question if someone can help me out http://www.helifreak.com/showthread.php?t=287945 ...
Old 03-15-2011, 07:33 PM   #18
flyinghigh450
4.9HP and should make more now that the motor pole setting is right and I can beat on it http://www.helifreak.com/showthread.php?t=288234 ..
Old 03-15-2011, 11:44 PM   #19
gr8taz nitro
The castle sounds wicked doesn't it.
I may have to actually go ahead and throw the 14T pinion on for a flight just to hear that scream. Mine sounds good, but that was just awesome!
Old 03-16-2011, 11:29 PM   #20
NRPY
Will that motor fit in the stock frame without modifications?
NRPY is offline        Reply With Quote
