| HeliDirect HeliDirect HDX300, 450, 500, 550, 600 Factory Sponsored Support Forum |
I recently purchased a set of replacement blades for my Lepton EX... In addition to the fiberglass ones, I got a set of the HDX425 carbon fiber blades which were advertised as symmetric and balanced (blade, span and chord).
When I examined them, they both appear to be warped. I am wondering if this is how they were manufactured or if it is a flaw in the set I have. Also, if it is per design, how will these perform for normal v. 3D flight? When I held a blade at the blade root, with the trailing edge to my left, I could see a pronounced curve to the blade downward at the trailing edge near the blade tip. Both blades appeared exactly the same (which either goes toward them being manufactured like that, or at least suffering the same warping forced in transit or while sitting in stock, etc). If they are advertised as symmetric, I would expect them to be symmetric around the horizontal plane between blade leading edge and trailing edge... So, can someone ease my concerns? How might such a warping affect the blade performance? Should I risk it? (Until I know, I'm just going to use the symmetric fiberglass blades)
Blade CP Blade CP Pro Falcon 3D Hirobo Lepton EX |
Team Taco VP
I have a set of those and mine are not warped at all.... You may have gotten a bad set...
Bob
"Don't Taco My Pack Dude!" To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
Thanks very much... I'll try for a return and replacement and try again.
