Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 03-16-2011, 06:47 PM   #1
JTAnimal
Default 550 Case
I was looking for a case for my 550E and all i can find is the bag cases but they only have 500 or 600 cases. does anyone know if these are any good?and can i use the 500 case?
JT
Trex 500, 550 & 600
Gob 700 & 700 KSE
JTAnimal is offline        Reply With Quote
Old 03-16-2011, 07:56 PM   #2
JTAnimal
OK i found some info that says the bag will only work with FBL. what are people using for a casce for a 550E FB?
JT
Trex 500, 550 & 600
Gob 700 & 700 KSE
Old 03-16-2011, 07:58 PM   #3
snaps11
The bag will probably work for the FB version you just have to loosen up your FB and slide it toward the tail when you are transporting it (PITA though). Otherwise im looking for a good metal case myself......
snaps11 is offline        Reply With Quote
Old 03-16-2011, 08:08 PM   #4
JTAnimal
yes i think thats what i will look for also.
JT
Trex 500, 550 & 600
Gob 700 & 700 KSE
Old 03-16-2011, 09:14 PM   #5
cbailey
The Align 550 bag will not zip with the FB version, about 2inches plus the paddle will stick out. Don't try to shove it in or you'll bend the flybar. It's really not bad just leaving it out a little. I stretched my 550, so it really won't fit in the bag anymore.
cbailey is offline        Reply With Quote
Old 03-16-2011, 10:03 PM   #6
Helis4me
Why don't you get a Trex600 bag and it will fit in there nicely.
Cheers!
Trex 600E Pro FBL with V-bar,600MX-510KV,HW 70A HV ESC,
CC BEC Pro,Align DS610,Futaba BLS251,
JR11X with Hyperion LifePO4,
Icharger 306B with Meanwell 1000W 24v power supply.
Helis4me is offline        Reply With Quote
Old 03-16-2011, 11:34 PM   #7
Smity777
Um I have a Flybar verson, and though it isn't an easy fit it doe fit in the bag and the bag zips up with no mods.
Smity777 is offline        Reply With Quote
Old 03-17-2011, 12:12 AM   #8
Wolfpackin
Mine fits too.
But IMO it's a real pain to get it in that way and the bag does put some pressure on the flybar.
I just leave the flybar sticking out and zip up around it. Not a big deal to me.
Jonathan Livingston Helicopter
Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.)
CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG.
T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades.
Wolfpackin is offline        Reply With Quote
Old 03-17-2011, 01:38 AM   #9
Helis4me
You mean in the Trex660 carry bag? Still tight fit?
It should fit in there nicely.
Old 03-17-2011, 01:55 AM   #10
Wolfpackin
I have the 550 bag that came with my kit.
Old 03-17-2011, 02:30 AM   #11
monsterbfc
This one is killing me too. I want a hard case for mine. I could have swore a sponsor on this board flashed that they had 500-600 size cases in a banner ad, but I haven't seen it since the one day.
"Ya, I'm obsessed, I admit it."
monsterbfc is offline        Reply With Quote
Old 03-17-2011, 03:02 AM   #12
Bytheway
I haven't seen any for 550's and 500 model is too short at 36" so we are definitely looking at these .50 size cases. Weighs up to 50 pounds... 53 inches long.... Personally I don't need a tank proof case, I'll keep my Align nylon bag!
http://www.heliguy.com/Extras/Flight...Trex-600-Case/
http://www.helihobby.com/category-s/...field_carriers
http://www.lightningpower.com/product_p/lp-m0118.htm
http://www.rcandme.com/align-metal-c...216#googlebase
alternative:
http://www.skbcases.com/
Bytheway is offline        Reply With Quote
Old 03-17-2011, 11:54 AM   #13
JTAnimal
That Lightning Power case is nice but 50lbs is a little heavy. i guess i will go with the bag. Thanks for the help.
JT
Trex 500, 550 & 600
Gob 700 & 700 KSE
