| CB100 Walkera CB100 Helicopter Support |
#41 |
I cut my CF rods on the balcony today on the 17th floor in upper east side manhattan with the mask on and goggles on and a vice grip on the balcony table. Was quite an odd site for the other buildings im sure.
My CB now has the 2.9g and the HP05s and a solid carbon boom and the clubheli struts and the extreme landing gear. Damnit I've run out of things to do to it and it flies perfect. I always feared this moment. At least my V100 has yet to be brought up to spec. I can see now why the 2.9g and HP05 are a 'good match'. The whole flight envelope seems more natural and its as if the technology level jumped to a super stable and controllable level. I guess I can still try the MIA flybar weights and main shaft collar to feed my heli enhancement addiction.
Walkera V120d02sV2, Mini CP, V100D01, CB100, Lama2 - Nine Eagles Hughes SX - Blade mSR, 120SR |
#42 |
Hey Hamish, adding flybar weights, will only make the heli sluggish.(more than the cb100 already is!)
Some people have a problem for every solution... |
#43 |
oh you're right, it says for increased stability....don't need that, i was thinking that there were less weight for a bit more performance.
#44 |
Have you experimented with the mixing arm ball positions?
Moving the ball to the inner hole will increase stablisation (flybar ratio INCREASES) - The CB100 will be less responsive. Moving the ball to the outer hole will decrease stablisation (flybar ratio DECREASES) - The CB100 will be more responsive. |
#45 | |
I am glad to read you are pleased with the upgrades you did. Can you tell me where did you buy the 2.9g and the HP05 motors? Thank you
Gazaur MARS 480 * TT Mini Titan E325 SE * Walkera UFLYS/CB180Z-Pro/CB100 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#46 |
Wow hobbies or Chinese jade !
CB100,MSR ,mCPX ,V100DO1 ,120D01,120D02,T-REX 250,T-REX 450,BLADE 400 |
#47 | ||
http://www.wowhobbies.com/tailholder...1-1-1-2-3.aspx For the main motor you want this http://www.wowhobbies.com/turboace81...ra4g6-2-1.aspx and this heat shrink for the tail joins along with some assorted sizes from radio shack http://www.wowhobbies.com/heatshrinktubing.aspx I also used this helping hand http://www.wowhobbies.com/utp-sku102...hledlight.aspx and this screwdriver which is now my favorite http://www.wowhobbies.com/phillipscr...rdenedtip.aspx
#48 | |
When you installed the xtreme landing gear, what kind of mod did you do yo the canopy to make it fit? I just installed the new landing gears on my new CB100 and ran into this issue. Can you take a pics at the point where the canopy meets the landing gear? Thx Thank you,
#49 | |
I'll take a pic if you still have troubles.
#50 |
Pics are welcome anyway. I just don't want to break the canopy trying to make it fit. Thx.
#51 |
I'm new to the fp helis and this website I'm just wondering if I buy the xteme blades do I need to buy the blade holder for them as well or does the stock blade holder support them
#52 | |
#53 |
Just the blades... no need for the holders.
#54 |
How exactly does the extreme landing skid go on. I look at my cb and the only thing I can think of would be a ca on the inside of my battery holder. Something tells me I'm wrong cause if it comes down a bit hard the skid will POP of like nothing was even there
Excuse my typing I'm using my andriod..... no computer. This is an awesome forum guys I like it ![]() |
#55 | |
#56 | |
When I bought the extreme landing skids from Clubheli, the kit came with pretty straight forward instructions including illustrations, so go ahead, order and just follow the instructions. Good luck!
#57 |
Well. I guess I'll have to stock up on canopies...
#58 |
Thanks guys
#59 |
I'm thinking about getting the HP05 and 2.9 upgrades for my cb what I'm wondering and haven't been able to figure out is if its necessary to upgrade the ESC for both motors or do the stock ones work.
#60 |
unless your cb100 is from last year than the stock one is ok. The ealier cb100s has a different tail esc which is why the wow sales copy suggests getting one.
Ill take some pics of my soldering of the hp05 to the main esc for you.
