| AHF Aeolus AHF Helicopter Support |
Hello again,
Nobody likes it, if someone flying an other brand (in this case my good buddy Sandro) touches your bird and after a while asks you, if a certain play or movement on your bird is common or just wear ? This happenend around 2 monthes ago, when my buddy hold the levers mounted on the elevator-arm-lever and stirring around asked me, why the elevator-arm-axle had so much play ? First thought he was kidding me, then took a look myself and indeed, the axle guided by the 2 flanges in each side-frame had lots of play. Removing the levers and looking at the axle guided by the 2 flanged-bearings showed, the flanged-bearings themselves having some play on their mounting-hole on the side-frames. Solution: 1.) remove the levers on the outer side of the side-frames 2.) degrease the side-frames around the flanged-bearings (inside and outside of each side-frame) 3.) use some JB-weld arounf the flanged-bearing and on the side-frames 4.) whipe away excessive JB-Weld 5.) use some water or alcohol on your finger, to make the JB-weld surface look nice Meanwhile both of my modified Aeolus 50 3D GFs have this mod and after many hours still w/o play. I guess, Im not the only one with this issue fortunately this can be solved very easely. Would be intersting to know, whether some of the guys with CF-frames eperienced the same ? So check your bird and mod if required, Best Regards, Oliver |
