| BeastX FBL System BeastX FBL Flybarless System Software and Hardware Support |
Trying to get my 500 up and running, got the beast x setup. when i went into my pitch curves on normal mode i dialed in -2 degrees, then i moved on to the others, and noticed that my pitches are all wrong.
meaning then when i dial in + pitch in the Tx my heli is giving me - pitch. I just switched to the DX7 from the Dx6i, so i am not used to setting up the dx7. is it someting i missed in the beast setup or is it in the Tx? thanks guys.
My tutorials: Trex 250 Carbon Fiber Tail Push Rod http://www.helifreak.com/showthread.php?t=238095 |
#2 | |
Next...if the collective is going backwards check two things. First since it is a FBL head you should have the link connected to the leading edge on the grips. Next if it is backwards(swash moves down with up collective stick) then reverse the pitch servo in the radio.
Trex 450 Pro 3xDS410M + MKS8910A+, Align FBL head w/Microbeast, CC 45 Gov@ 3400rpm(max timing, outrunner mode), Scorpion 2221-8 on 14t, Edge FBL main and tail, CF boom, CC BEC @ 6V |
It can also depend on other things. Check the beast's compensation for cyclic movements, you might need to reverse the direction in the beast setup menu I, maybe even in M instead of the radio. To be honest I did not have to change the directions in the radio, could do it all on the beast itself.
I am a HeliCoholic! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Fusion50FBL μBeast TRex500FBL μBeast Blade 130X Blade Nano Spektrum DX8 Blade 120SR handbuilt Coastguard AW109 see my avatar For the winter:Reflex XTR
