Go Back   HeliFreak > R/C Helicopter Support > Henseleit
Henseleit Henseleit Helicopters
Old 03-06-2012, 05:31 PM   #101
billiano
If you were able to buy a 2nd motor for the TDR just for the extra speed and power which one would be?
Keep in mind,I use 65C 5000mAh Batts.
a. 4530-540LE
b.4525-520LE
c.4525-520LE Ultimate
Bill
Esprit Model Flying, TDR Rigid x2
F9 Fiberglass Europe Canopies
billiano is offline        Reply With Quote
Old 03-06-2012, 07:01 PM   #102
KidHeli
what's the difference b/t the regular 4525-520le and the ultimate? is it the winding?
KidHeli is offline        Reply With Quote
Old 03-06-2012, 08:01 PM   #103
jhunter
Default Yes
Le -delta
Ultimate - yy
TDR, Srimok N x 2, Banshee 31, Dune!
jhunter is offline        Reply With Quote
Old 03-06-2012, 08:04 PM   #104
mkovalcson
So the 4525 Ultimate should be a good powerhouse motor that the Jive likes ?
Mark
2011' Protos 500, 2014' Logo 550SX, 2012' TDR, 2015' Protos Max V2, 2016' TDR2
2013' Jeti DS-16
mkovalcson is online now        Reply With Quote
Old 03-06-2012, 08:13 PM   #105
jhunter
Default That is the theory
They don't seem to mind the larger le motors that are yy
Old 03-06-2012, 08:42 PM   #106
helicraze
Get the 4530
helicraze is offline        Reply With Quote
Old 03-06-2012, 10:03 PM   #107
Vinger
Originally Posted by helicraze View Post
Did a little maintenance on the TDR, after 100 flights with the LE motor i replaced the main gear (little worn on the lower half) lower bearing on main gear (where one way is) was rough so i replaced that (same size as LE motor bearings, just heat and tap out), lubed the one way bearing, move a shim to tighten up the tail drive gear backlash.
These motors have monster torque and twist the frames. Also i want to find better washers for the motor mount bolts, even the radix tail spacers after using them once, the 2nd time they mushroom in.
I made a carbon fiber plate that covers both screws on each side of the motor mount, about 12mm wide. Then use 3mm longer bolts with cup washers, never had a problem since.
Gaui R5, Henseleit TDR +TDR2, Banshee
Kontronik ESC, iChargers, VBar, VControl, JR XG11
Old hand at Planks
Vinger is offline        Reply With Quote
Old 03-06-2012, 10:06 PM   #108
ElectricSheep
+1 to what HC said... Get it if you can find it. From what Scorpion said, only 100 were made. So I guess that would make it a true "limited edition" and not an "LE" (like the Align kind of "LE")...
Tapatalk on iPhone
ElectricSheep is offline        Reply With Quote
Old 03-06-2012, 10:13 PM   #109
marcosp
And between this 4530LE and a PowerCroco rewound 4530 5+4YY x1.7mm approx 580kv used for a record 166mph??
Isn't the 4530 still usable as a normal motor and the Croco exclusively for speed?
Marcos
Banshee #27, 2x TDR, Diabolo, Logo 690SX, Raptor E700, JR Sylphide E12 EX Super Gracy, Voodoo 600, Voodoo 400, Logo 550SE, Logo 400SE, JR Forza 450. Mikado Vcontrol.
marcosp is offline        Reply With Quote
Old 03-06-2012, 11:59 PM   #110
goready
Default HK 4530-540
Tapatalk on iPhone
You still can get the HK 4530 from scorp. I've just received mine. No.118
goready is offline        Reply With Quote
Old 03-07-2012, 01:05 AM   #111
helicraze
They re released the 4530LE
Old 03-07-2012, 01:24 AM   #112
ElectricSheep
Wow, I stand corrected -- so Scorpion *does* mean "Limited Edition" in the same way as Align does...(!)
I guess if they named/advertised the product truthfully, it would be called "4530 NRLE" -- as in "(Not Really) Limited Edition" and I guess they wouldn't sell as many units... Maybe.
Tapatalk on iPhone
Old 03-07-2012, 03:16 AM   #113
billiano
I really do not mind being limited..
But to be powerfully bad...
Bill
Old 03-07-2012, 03:27 AM   #114
Heli G
a. 4530-540LE
b.4525-520LE
Neither of those. I would get a custom wound 4035 (5T+6T 1.4mm YY). Very powerful motor that runs cool with plenty of power for speed. I've tried my best to bog my croco 4035 in 3D with no luck yet.
Heli G is offline        Reply With Quote
Old 03-07-2012, 03:57 AM   #115
shaman3
The bigger motors shine at lower rpms (due to torque) and speed runs (delivering high power for long(er) periods). For 3D, the 4035 certainly does the trick When delivering the same power, the 4035 will always get hotter than a 45xx as the efficiency is nearly the same (at least if custom wound) but the mass is lower.
Having tested all kind of different motors in my TDR, I would say the 4525 is the "sweet spot" for the power hungry all-purpose flyer. More than that only makes sense in a dedicated speed machine.
Daniel
shaman3 is offline        Reply With Quote
Old 03-07-2012, 04:17 AM   #116
mkovalcson
I think I probably should maiden my first TDR with its Pyro before I get power hungry
Jan says it should satisfy 90% of the pilots out there, I may be one of them.
Mark
2013' Jeti DS-16
Old 03-07-2012, 12:39 PM   #117
worldofmaya
I second that... Pyro has lots of power with low weight. With a light setup and 1800 to 1900 you have some really great performance with decent flight times and without the need for super-expensive batteries... don't take the power route, it just costs money, flight time and increases maintenance cycles...
-Klaus
SuziLAOS-DNHP-CenturioMax-Protos500-DJI-F550
worldofmaya is offline        Reply With Quote
Old 03-20-2012, 05:10 PM   #118
billiano
Friends I got my 4530-540LE today.....
I followed the posts and got the shims that HC proposed.
But one question that I have to ask.
My motor cables are Red-Blue-Yellow while G-Bru's are all Blue on the other
hand CNCjunkie's cables are all White.
Am I missing smthng?
By the way I got #133
P.S:I tried after 30 flights ,this weekend the Pyro with 14th instead of 13th and 50-65% the HeliJive instead of 65-85%and it rocked for 7min max time but the temps from 20C went to 45C (env temp 20C)
So I will try it for some more flights since the 14th are better and give 7min flights with the Pyro
Bill
Old 03-20-2012, 05:37 PM   #119
ZuvieleTeile
The color doesn't matter.
They probably take what they have in stock . . .
Kind Regards ZT - TDR,
No problem can be solved from the same level of consciousness that created it.(AE)
ZuvieleTeile is offline        Reply With Quote
