| Electric Helicopters - Only E-Helis *No Commercial Ads - E-helis Only |
Decided to sell my Trex 500 and step up to a larger heli (Compass 6HV.)
This airframe has about 500 flights on it total but you wouldn't know by looking at it. About 60 flights ago I went through the entire heli and replaced end links and pivot balls as needed , checked all the bearings bearings and repacked all bearings using "The Greaser." The airframe is in great shape. The heli is a mish-mash of early and later ESP parts, so to clarify here is the current airframe configuration: Align G-10 frames with lowered battery tray K2 Heli front & rear frame stiffeners Full metal head with Mikado FBL head conversion (much better mechanical resolution than Align FBL head) Plastic main bearing blocks KDE motor mount Torque tube tail ESP Metal tail grips with Heim Joint's Chinese weights Aluminum boom strut clamp Aluminum tail servo mount clamps Full size graphite tail servo plate (graphite plate for mini-servo also included) RDLohr extended gyro/receiver tray Radix 72mm cosflaw tailblades The Fusuno canopy included was involved in a light crash about 100 flights ago and has some missing paint. It's still structurally OK but isn't cosmetically perfect and has some paint missing on the windscreen and left side. Spare parts inventory includes: 1x Trueblood swash leveling tool 1x main thrust bearing kit 2x MS Heli main bearings (they go longer before getting sloppy compared to the Align main bearings) 1x Kasama thrusted main bearing block set 1x bottom frame plastic kit (bottom, battery tray, gyro tray) 2x rear TT gear set 1x front TT gear set 1x autorotation gear 2x frame hardware packages 1x mainshaft 1x feathering spindle 1x autorotation hub sleeve 1 package tailbooms (2x booms, 1x control rod) 1pr tail boom struts 1x spare main head block 2 packs of gray head dampers 2 packs of Trueblood green dampers Several packs of canopy grommets Several packs of spare links, rod ends, and pivot balls 1x tail hub assembly with plastic blade grips 1x spare Mikado FBL conversion swash driver 16T pinion 17T pinion Asking $300 including shipping & paypal for the airframe and spare parts lot. PM me if interested. See my classified listings for other Trex 500 related parts such as JR 3517MG servos, a Neu 1706/1.5Y motor, and 2 additional canopies. Also available is a carrying case. This is a Plano bow case that I built a custom foam insert for. The insert will hold the heli, 6 battery packs, 1 cutout for tools or miscellaneous parts or a 7th pack, and the TX cutout has been tested to fit a DX7 and DX8. The case is optional and will add quite a bit of shipping charges so keep that in mind. If you just want to buy the case keep in mind this case is cut for an FBL Trex 500 and the foam cutout WILL NOT FIT A FLYBARRED HELI. I'll sell case for $45 but I'll have to know your ship-to zip code to figure out the shipping charges. It will probably be $35+ in shipping charges simply because of the size of the case (44 x 20 x 10, so "dimensional weight" charges apply.) If you are interested in the case please PM me with your ship-to zip code so I can provide an accurate price including shipping.
Goblin 700 - HC3SX, Mezon 130, 750MX, 12S, BLS451/BLS251 Bergen Magnum 44 - HC3SX, Wren MW44 turbine, BLS156HV/BLS256HV Jeti DC-16 Last edited by TowPilot; 04-11-2011 at 02:12 AM.. Reason: Edited on behalf of OP |
Buyer flaked, back up for sale.
Will now include blue Align canopy from this ad: http://www.helifreak.com/showthread.php?t=291562 4/11: SOLD
Goblin 700 - HC3SX, Mezon 130, 750MX, 12S, BLS451/BLS251 Bergen Magnum 44 - HC3SX, Wren MW44 turbine, BLS156HV/BLS256HV Jeti DC-16 Last edited by Kiba; 04-11-2011 at 11:20 PM.. |
