Go Back   HeliFreak > R/C Helicopter Support > Avant RC - Mostro & Aurora
Avant RC - Mostro & Aurora Avant Mostro, Aurora, Electric eAurora, RigidCore Flybarless Head, Avant EFX and Avant FX Helicopter Support
Old 03-26-2011, 07:28 PM   #1
TheBillMan
Default The hardened pin that locks the constant drive hub into the main shaft
I have a quick question concerning the hardened pin that locks the constant drive hub into the main shaft. I’m currently having a problem with centering the 4mm pin through the shaft. For some reason my main shaft and hardened pin did not fit through the holes very well at all without slight modification. So, the question is... If my pin is not centered all way through the hole on the shaft will this possibly cause a bad vibration on the head because it’s not balanced? I’ve attached a picture of the assembly.
By the way, my kit is the newer 2010 version of the Aurora nitro.
Thanks in advance for your help!
TheBillMan is offline        Reply With Quote
Old 03-27-2011, 04:54 PM   #2
Laurens
I'd want that pin all the way through. Is there really no way you can get it through? Maybe tapping it lightly with a hammer will work.
Logo 800/Jeti DS16
Laurens is offline        Reply With Quote
Old 03-27-2011, 08:26 PM   #3
questerng
this is definitely not right.. there should not have to do any mod.. I'm suspecting that you have one of those component in 3mm and 4mm.. I would use a 3mm pin and the 4mm pin to check the gear and the hub separately.. to see which one is wrong and replace..
Q
life is not the amount of breath you take, its the moment that take your breath away
questerng is offline        Reply With Quote
Old 03-27-2011, 08:28 PM   #4
questerng
sorry..my bad..
what I mean is the hub and main shaft..
Old 03-28-2011, 12:52 AM   #5
FBLessOne
don't sweat it just send those parts to Avant:
http://www.avantrc.com/support/showthread.php?t=538
FBLessOne is offline        Reply With Quote
Old 03-28-2011, 02:32 PM   #6
TheBillMan
I just sent in the whole assembly to them today for their inspection by Express Mail.. It looks like the main shaft or the hub sleeve for the one-way sprag bearing was warped/bent or not true. This caused the 4mm hardened pin not to go through the shaft all the way… Also when I mounted the assembly to the frame along with the clutch assembly, the main gear was completely out of sync with the clutch pinion gear mesh..
Anyhow, thanks for all your suggestions and help…. Hopefully Avant will send me out the replacement parts quickly, so I can get on with the rest of my build!
Old 04-01-2011, 08:22 PM   #7
TheBillMan
Here's what Avant found on the part assembly that I sent them. I'm really impressed on how good their Service Support handled the issue and turned around the bad parts.
Kudos to Avant Service Support!!!
Originally Posted by Avant Service Support
Dear Mr. TheBillMan,
We inspected the parts you sent and found that the sleeve's holes were out of center and the sleeve itself was warped apparently from the heat treatment. We replaced the main sleeve and the main shaft. We assembled it all and checked the gears for roundness now and they check out fine. We also completed the threads on the bearing block and they are now deep enough for the 25mm screw.We are shipping them via Priority Mail and you should have them back in a couple of days.
Sorry about the delay that this caused you in your build.
Best regards,
Fernando,Customer ServiceAvant RC
Old 04-01-2011, 10:12 PM   #8
FBLessOne
nice
Old 04-03-2011, 03:59 PM   #9
Laurens
Logo 800/Jeti DS16
