| Outrage 550 Outrage 550 Helicopter Factory Support Forum |
nice battery def sounded like it was strong , i kept the hs at 2100 and didnt slam it at all this was its first flight kept it gentle up n down hover and a tiny bit of ff for 3min . i hope it holds up as well as my other 2 zippys did last season
Yea, they are good performing packs. Do you know the IR of your's? Mine are at 3 or 4 for each cell which I think seems a little high? Also they get "warm" when I am only discharging 180 or so amps (in burst) but they are rated to 325 continuous and 450 burst, so it seems kinda odd they are getting warm at around half there rating.
Other then those 2 concerns of mine, they really perform great and pack a nice punch.
Compass, ProStar Hobby, Giant Power, OnlyFineHelis, Protek/Amainhobbies 7HV, Warp, 3D+ Lincoln To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. ):> |
I will check the ir tomorrow, i picked up for tonight when i broke the throttle extension trying to change gov gain on the ice100 ,
edit i was curious so total was 17m ohm total 2^2^3^4^3^3 i did notice just a mild hover the pack temp went up a lil i dont remember the zippy doing that .then again its 70++ here |
Ok that's about where mine are. After that flight I posted the video of yesterday, my pack was had an internal temp of around 85 degrees according to my charger, it was about 45 degrees outside and really windy.. (had to hold on to it to keep my hands warm lol)... seems really warm to me and I really wasn't pushing them to hard. I would like to see stats on a TP 65C pack.
My XPS cells are all 2, 3, or 4s... that's REALLY low guys. Turnigy packs are like 70 I've heard.
It's not just a hobby... it's a lifestyle! Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo Pete Team Outrage. |
#6 |
You sure?? My friends Nano Techs (for a 500) were like 8 or so I think after 30 cycles, which yea that's alot, but I've also heard regular turnigys getting like 0's and 1's.
I will test my NRG pack (for a 450, I use it for my plank) and see what that is.
#7 |
Gens Ace have been recorded to be 1-2 mOHM after about 30 flights. Maybe one of you guys can do a comparison with the Gens Ace 30C 5300 mAh LiPo, which is smaller and lighter than the XPS. Also, remember that a 25C Gens Ace is equivalent to a 45C Thunder Power, so their 30C, might be like the 65C XPS. Anyone gonna try them?
http://www.hobbypartz.com/98p-30c-5300-6s1p.html
Blade 130X Xtreme-Production
Blade mCP X (Bl) Blade Nano CP X Prôtos 700 |
#8 |
If I kill a pack those are the next ones I'll try.
#9 |
If you kill a pack, make sure it's a taco
#10 |
Yeah you can't.. they just push in.. mounted in the frame
#11 |
I thought they were hard to do because of the battery bay, but I am hearing of people doing them.
Sly you need to build a super cheap $9 HK 450 clone kit heli with the cheapest pack you can find and slam it into the ground, just to get into team taco
#12 |
$10 HK kit, $4.99 RX, $2.77 servos, $10 Xheli motor, $15 ESC, $10 Lipo, $9.99 gyro and you may want to buy a second $10 kit in case you don't crash the 1st one hard enough.
#13 |
I would actually probably do that, except I honestly would not feel safe spooling that thing up near me.
#14 |
I already own a vise grip and a hammer....
#15 |
True that. Just don't do it to one of you XPS packs!
#16 |
I have six XPS 6S packs and each one is in the 2-4 range. I also have six 3S XPS packs and each one of those is in the 5-10 range. However, with my 3S packs, the IR readings seem to be getting better as time goes on. A couple of them started out at 10 and now they are at 5 after 8 cycles. My 6S packs have been consistent and have about the same IR readings after 15 cycles.
For comparison, I have four Turnigy packs that Pete sold to me that are in the 4-7 range. (One of them has a bad cell that has an IR of 14 so I don't count that one) Pete - how many cycles would you say you had on those packs before you sold them to me? Tommy
Trex 700E FBL - PowerJive 120HV, 700MX, Fullsize Vbar, Telemetry, WR Super BEC, various KDE Upgrades Outrage 550 FBL w/mini Vbar, NEU 1907H1Y, CC 125A ESC, WR Super Mini BEC Outrage 550 - same as above but with flybar |
#17 | |
JK. in the 70 cycle range. That's amazing how low their IR is! Hey I forgot to ask you .. do you notice a difference flying your 550s between the Turnigy's and XPS packs?
#18 | |
Tommy
#19 |
Interesting. Those Turnigy packs are really good. But I bet we see more cycles with our XPS packs though.. and I am sure enjoying my charge rates.
Today I charged my first two packs at 30A (3C for each pack) and they were done in 16 minutes... that equates to 8 mins per pack. Unreal.
#20 |
BTW - I think it does make a difference when you test IR. I've noticed that I get zeros or 1 right after a charge but if I let it sit for a bit or test at storage level then the readings are a bit higher. Is there a general rule that you should follow when testing for IR? Test at storage level? Full charge?
Tommy
