Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 200
Hurricane 200 Discussion and support of the Gaui Hurricane 200
Old 04-08-2011, 12:50 PM   #41
nexgen
parallel charging 2 packs actually takes less time than charging each one separately, sounds counter intuitave i know but it does work. check out this guys website for some good info on how to do it.
How-To: Parallel Charging
I use the same thing he does.
EP Buddy ParaBoard
GAUI Field RepbeastXTeam Empire Hobby
Gaui 200 •Gaui 550 •Gaui X5
BeastX Castle Scorpion Hyperion Spektrum JR
nexgen is offline        Reply With Quote
Old 04-08-2011, 01:37 PM   #42
Mikegigabyte
EP Buddy ParaBoard
wow great tool, I will look at that later. I will have to study that page that sells the parts to make sure I get the correct one
too many things to look at right now
Mikegigabyte is offline        Reply With Quote
Old 04-08-2011, 06:28 PM   #43
Mikegigabyte
I ordered this
So if I have 4 800 ma 3s do I set my charger to balance and output 800ma 3s
so it will still take the same amount of time but do all the batteries at once or do I need to be concerned about my charger limits it can handle. The biggest multiple batteries I would charge are 2100 3s
Old 04-08-2011, 08:43 PM   #44
nexgen
Do as 3s. But set as 3200mAh (4x800).
Old 04-14-2011, 12:31 PM   #45
egicar
Here is my EP100 PRO 3 blades, in the AS350 Ecureuil fuselage.
I choosed to put the servo arms pointing to the shaft.
ID:	221785   Click image for larger version
GAUI addict: EP100 PRO, EP100 V1, EP200 V2 BeastX/satellite, EP255 BeastX/satellite.
Now, TREX 250 SE BeastX/satellite as well.
egicar is offline        Reply With Quote
