Go Back   HeliFreak > R/C Helicopters > R/C Helicopter Tools and Supplies
R/C Helicopter Tools and Supplies Tools and Products used with R/C Helicopters
Old 04-08-2011, 04:07 AM   #61
WillJames
Originally Posted by Cletus View Post
WITHOUT PREJUDICE
I fail to comprehend why it's suddenly classified as "Off-Topic" though.
Are we not discussing a tool/device/contrivance directly related to the assembly/dis-assembly/repair/maintenance of R/C helicopters and related assemblies?
......and, are we not doing so, while still having fun, learning and exercising friendship and mutual respect?
I moved it to OT. Read this rule right here - http://www.helifreak.com/showthread.php?t=96
It looks like the thread is back on track, but it needs not turn into any issues between manufacturer/dealer/designer, etc. Thank you.
William James
If you fly you are going to crash.
WillJames is offline        Reply With Quote
Old 04-08-2011, 04:13 AM   #62
WillJames
Originally Posted by Ah Clem View Post
A long time ago, on this forum, someone suggested using a drill chuck for this purpose.
I keep a spare drill chuck in my tool box and it works extremely well to remove the second bolt from the spindle.
That is what Alan my flying buddy and also a contractor here does.
William James
Old 04-08-2011, 06:09 AM   #63
rdlohr
Originally Posted by Finless View Post
OK so this is not to discredit these tools but since I have never had one I have used vice grips, etc. There is a way to do this without worrying about possible marring of the spindle and if you do it wont hurt anything. What I do is remove the one screw and pull the grip off. Then push the spindle out of the head. So now you have a grip and spindle in hand. Now most helis I have had there is nothing in the center of the head touching the spindle that some marring of the spindle would effect. So I grab the spindle with the vice grips right in the middle and take the other screw out. If I marred the spindle in the middle I do sand it to get any burs off it just for grins but as I said the marring here in the center wont hurt anything.
Bob
+1. This is what I have always done. I usually slip a strip of rubber over it to keep from marring the middle of the shaft.
I think I will still buy a tool anyhow. Looks handy.
Rick
Helifreak, the place to be!
Rush 750,Logo 400SE 600SE, TREX 450SE, 500, 600, Blade mCPX,130X
My products, flown by top pilots around the world, like you!
rdlohr is offline        Reply With Quote
Old 04-08-2011, 08:06 AM   #64
RĒzĒ
don't forget that if a bolt is in super tight due to loctite (especially red) to heat up the end of the shaft and that will help get that bolt out without having to put the shaft in a vise (like I had done one time heh) I almost broke a thorp driver it was in so tight lol
RĒzĒ is offline        Reply With Quote
Old 04-08-2011, 09:20 AM   #65
nightflyr
I've always used a 1 1/2 inch V-groove machine vise to hold the shaft while loosing the screw, has yet to ever fail holding any diameter feathering shaft.
Nice tool though, and I wish the best to all who sell them.
MSR, MCPX, 450s, 600, 650, 700, 800, 900, 1000
Assorted
Mix Fixed Wing.
AMA # 972083
Old 04-08-2011, 11:51 PM   #66
wolfdown
A good way to grip the spindle is to wrap a sheet a saran wrap around it and grip with some joint pliers or vice grips. It will not scratch or slip.
That being said ... I'm going to buy a grippy as soon as I can get one.
Rush 750 w/ Xera 4530-500 (12T), YGE160HV, WR S.BEC, Torq 9180/9188, AR7200BX
Outrage 550 w/ Scorp 4020-1390 (13T), YGE120, CC BEC Pro, Quark, MKS BLS980, Futaba BLS451
Last Rebuild: 10/15/12 (O550)
wolfdown is offline        Reply With Quote
Old 04-10-2011, 01:34 PM   #67
raptorJoe
I can't believe I read this whole thread
raptorJoe is offline        Reply With Quote
Old 04-11-2011, 04:26 AM   #68
Wazzer
LOL +1
Wazzer is offline        Reply With Quote
Old 04-11-2011, 04:28 AM   #69
Wazzer
LOL +1
Old 04-12-2011, 10:13 AM   #70
Rototerrier
Wrap spindle in paper towel or rubber or towel and stick the entire length into the jaws of a table vice. Crank it down. Doesn't take much since the vice is distributing the grip along the entire length of the shaft. Remove bolt.
No cratches and very little force applied to the shaft at any 1 point.
I only have one of those small $19 vices from Lowes (Kobalt). Not sure how much these tools cost..but I am 100% sure I get more use from my vice outside of removing bolts from spindles.
TREX 700 Helibug GASSER 16t | ĩBeast | JR8717 | TRM 270TT | GV1 | R921 X9303
TREX 700 Helibug GASSER 20t | ĩBeast | DS610s | Hanson 29 3D Max | GV1 | R921 X9303
TREX 550 V2 DFC | AR7000 | ĩBeast | CC Ice 100 | CC BEC Pro | DS650 Tail | 520 Blades
Rototerrier is offline        Reply With Quote
Old 04-16-2011, 06:10 PM   #71
Mercuriell
A leather belt in the jaws of a Mole Grip works well too but most times I take spindle out it's damaged and destined for scrap
John
Mercuriell is online now        Reply With Quote
Old 04-16-2011, 06:42 PM   #72
lazor 22
They have them listed at heliproz now, $20 a pop $30 for the "Duo".
Compass, ProStar Hobby, Giant Power/OnlyFineHelis, Protek/Amain
7HV, Warp, 3D+
Lincoln
lazor 22 is offline        Reply With Quote
Old 04-25-2011, 08:56 PM   #73
EatMorePizza
Originally Posted by backburner1955 View Post
4mm for the 450 Pro and 8mm for the 600's.
I would just get the two combo tools, that will cover 4mm, 6mm, 8mm, and 10mm.
on the 8 and 10 combo tool why would they put the smaller one way on the outside if you need more leverage for the 10mm???
TREX 500-neu/kde 1907/1Y -14 PINION-DE 6A BEC-AR6200-JR 3517MG-8900G TAIL-CC 75 ICE MINI V
TREX 700E-NEU KDE 1917-12 PINION-PRO BEC-MIKADO BLUE LINE -JR 8717 HV CYCLIC-8900G TAIL-ICE 160-KDE UNIVERSAL MOUNT W/PINION SUPPORT
EatMorePizza is offline        Reply With Quote
Old 04-25-2011, 08:59 PM   #74
EatMorePizza
before my drill press broke I would drill a hole through the center of the spindle and poke an owl through the head button hole and through the hole in the spindle to secure it while I loosen the main grip bolts.
Old 05-03-2011, 10:20 PM   #75
360Wings
I normally just use my power drill to hold the spindle in place whilst I remember the screw. I just use it as a vice as it doesnt damage the spindle.
360Wings is online now        Reply With Quote
