Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 04-07-2011, 02:10 AM   #1
Firesuite
Default BEC Pro on Stock FBL setup
Im now putting the Electronics in my bird, Ive been reading around on the internet and on the forums here, just wanted to run this by you guys with experience before I go and plug it in and fry it all
Stock 600mx motor | AR7000 RX | Align RCE-BL70G ESC and BEC pro.
Correct me if Im wrong ..
BEC pro installs as per directions in the packaging.
1. Two wires go to whatever spare ports I have on the RX (one AUX port and the Battery port)
2. I dont have to remove the Red wire from the ESC throttle cable because its not used by the Align ESC ?? (Finless mentioned this in one thread)
3. I dont need to change any voltages with the BEC pro, I can run it all at stock with my stock align stuff..
Thanks all..
450 Sport | HS65MG | S9257 | DX7
550e FBL 3G and loving it!
http://www.grahamgilmore.com
Firesuite is offline        Reply With Quote
Old 04-07-2011, 02:33 AM   #2
BakedMopar
The stock 550e esc has a built in bec so you DO have to take out the red wire from the esc rx plug.
BakedMopar is offline        Reply With Quote
Old 04-07-2011, 04:38 AM   #3
Fullonoob
I think its a good idea to use a separate BEC so your ESC won't fail in flight.
Fullonoob is offline        Reply With Quote
Old 04-07-2011, 05:13 AM   #4
1004ron
The way you put it one would assume that the stock ESC will fail if you don't use a separate BEC, which is not actually true.
Using the separate BEC reduces the risk of the ESC failing as a result of high demands or overload on the internal BEC.
There's many FB and FBL users running the stock ESC and internal BEC.
SAB Goblin 700 - CCHV120 - BEC Pro - AR7200BX - TM1000 / 450 Pro - GT5 - Tarot head / T-Rex 550 V2.1 - CC100 - BEC Pro - AR7200BX - TM1000 /
1004ron is offline        Reply With Quote
Old 04-07-2011, 08:26 AM   #5
garyji
+1 !!!
G.
T-450 Sport FBL, T-550 V1 FBL, Red Goblin 700. Goblin 500. 350 QX. Bunch of little Blades, and Planks. DX8, Retired Full scale Jet Plank Driver, U.S. Navy Ret.
garyji is offline        Reply With Quote
Old 04-07-2011, 08:36 AM   #6
Addictedd
has anyone managed to get the BEC wires and the ESC wires into 4mm bullets? I can't seem them fitting but unsure what to do as all my lipos are 4mm bullets so don't particularly want to change everything just to accommodate my BEC!
Addictedd is offline        Reply With Quote
Old 04-07-2011, 09:34 AM   #7
Firesuite
Thank you guys, I will pull the red wire from the throttle cable then for sure.
Has anyone using this on a 550e had to change the voltages in the BEC? My LHS told me there is no need to change anything, it will run as it is.
Old 04-07-2011, 09:36 AM   #8
Addictedd
no need to change voltage, the default is set at 5.1v
Old 04-07-2011, 08:23 PM   #9
bad007
IMO higher voltage, Higher voltage = faster servos and stronger holding power. FBL likes fast servos, I run 6.5 volts and now have way better responce and performance.
bad007 is online now        Reply With Quote
Old 04-08-2011, 08:40 AM   #10
GT86
My servos seemed a bit jumpy at 5.1 volts. I bumped it up to 6 and they smoothed out a lot.
GT86 is offline        Reply With Quote
Old 04-08-2011, 09:46 AM   #11
Chris_M
I would definitely plug it in to your computer to see what voltage its at right now. There's no telling if someone made a mistake programming it and how many volts its running at out of the box. Then you can set it at whatever you want depending on what electronics your running.
Chris_M is offline        Reply With Quote
Old 04-09-2011, 03:47 AM   #12
Fullonoob
default is 5.5v
Old 04-09-2011, 12:08 PM   #13
JTAnimal
My default was set to 5.1 I set it to 6VDC
JT
Trex 500, 550 & 600
Gob 700 & 700 KSE
JTAnimal is offline        Reply With Quote
Old 04-09-2011, 12:46 PM   #14
cupracing
Defaulting is 5.1
cupracing is offline        Reply With Quote
Old 04-09-2011, 12:47 PM   #15
1004ron
My default was also 5.1v, and I have set it to 5.5v
