Go Back   HeliFreak > R/C Helicopter Support > Outrage RC > Outrage 550
Outrage 550 Outrage 550 Helicopter Factory Support Forum
Old 04-08-2011, 09:34 AM   #1
Daddyo79
Default 8 C charging?
OK...
So I was charging 3, 5000 mah packs in parralell last weekend at 1 C (15 amps), left the room for a bit and when I came back I noticed my power supply (47a from feathermerchant) had shut down. I pulled the plug and looked for a reset button, but there was none. I was starting to cuss in my head thinking the power supply had crapped out, when I noticed my lead wires from the power supply to the charger were FRIED!!!! The insulation had melted off them!
I put new wires on, 10 gauge, and fired everything up again. After a couple of minutes I reached down to feel the wires running to the charger (15 amps, 3C if it was one battery) and those suckers were HOT! After playing with it a bit I've found that the biggest load I can put on those wires is about 13 amps.
Now, HOW THE HELL CAN YOU CHARGE AT 8C IF THE WIRES BURN UP at 3C???????
Are there super big gauge leads available for the i306b? There's no way the leads that came with it can handle 40 amps! Am I missing something? It's OK to tell me I'm wrong... I'm married, I'm really used to it!
T-Rex 250; T-Rex 450 Pro w/ Hitec HS65s and Futaba tail; Outrage 550 with Neu 1907, spartan quark, DS610 and 650 servos; Outrage Velocity 50 on the bench
Daddyo79 is offline        Reply With Quote
Old 04-08-2011, 11:53 AM   #2
tptompkins
Weird. I have a 3010B with 12 guage wire and I charge at 27 amps no problem. My wires aren't getting hot like that. It sounds like you have some sort of issue going on with either your PS or your charger but I'm not sure what the issue could be. Maybe somebody else can give you more insight.
Tommy
Trex 700E FBL - PowerJive 120HV, 700MX, Fullsize Vbar, Telemetry, WR Super BEC, various KDE Upgrades
Outrage 550 FBL w/mini Vbar, NEU 1907H1Y, CC 125A ESC, WR Super Mini BEC
Outrage 550 - same as above but with flybar
tptompkins is offline        Reply With Quote
Old 04-08-2011, 01:01 PM   #3
lazor 22
I charge at 30 amps all the time with no problems. Man you have just been having bad luck. Hope it gets better for you.
Compass, ProStar Hobby, Giant Power/OnlyFineHelis, Protek/Amain
7HV, Warp, 3D+
Lincoln
lazor 22 is offline        Reply With Quote
Old 04-08-2011, 01:07 PM   #4
DominicD
The Capi - HF Support
Is it a 12V or 24V supply ?
SAB Heli Canada / RotorQuest/Compass
Team KBDD
DominicD is offline        Reply With Quote
Old 04-08-2011, 01:08 PM   #5
Slyster
Tommy.. thats because you are charging at 24V. The charger can't go over 15A when only powered by 12V.
If I tried 12V at 30A (if it could do that) the wires would be really HOT.
It's not just a hobby... it's a lifestyle!
Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo
Pete Team Outrage.
Slyster is offline        Reply With Quote
Old 04-08-2011, 01:12 PM   #6
lazor 22
Oh right, do you have 2 of them hooked together or just one? Mine are 2 hooked together to make it 24v 47a.
7HV, Warp, 3D+
Lincoln
Old 04-08-2011, 01:49 PM   #7
tptompkins
Right - I was assuming that he is using a 24V PS. I don't have a feathermerchant PS. I'm using two P350s hooked in series.
Tommy
Old 04-08-2011, 07:10 PM   #8
Daddyo79
Ahhhhh!
Yeah... this is a 12v 47A power supply.
So if I connect this hummer (i306b) to my truck battery at idle, I'll be able to charge at higher amperage without burning up the wires?
Old 04-08-2011, 07:16 PM   #9
lazor 22
Buy another one of them and hook them together. It's not that hard to do really. He has instructions on his RCG blog.
7HV, Warp, 3D+
Lincoln
Old 04-08-2011, 07:32 PM   #10
Slyster
Originally Posted by Daddyo79 View Post
Ahhhhh!
Does your hummer use 24 volts? My van uses the typical 12V car battery but if the Hummer uses 24V you would be fine. The wires would run much cooler.
Pete Team Outrage.
Old 04-08-2011, 07:36 PM   #11
Daddyo79
errr... I didn't mean H2 or H3 kind of hummer, I meant it as slang for my power supply!
Old 04-08-2011, 07:38 PM   #12
Slyster
Oh.. LOL.. I was thinking "this guys rich!!"
SO now I see where I read to fast.. so your truck.. that's 12V too no? you need TWO car batteries in series to get 24V.. that's what I do.. although I use deep cycles.
Or like Lincoln said hook two PSU's together
Pete Team Outrage.
Old 04-08-2011, 08:44 PM   #13
rmalt
Don't forget to calculate how many watts are required.
Pulse XT 60 Saito 100
~KBDD Team Pilot~
rmalt is offline        Reply With Quote
