Old 04-09-2011, 02:41 AM   #1
FurryTrex
Default DX7 w/ BEASTX Pitch Curve Question.
I am not sure if this is in the right section, but since it has to do with the Tx I will post it here.
Setting up my BEASTX, and I switched the setting to use TX settings.
I put in the pitch curves according to the Align Manual.
I noticed in the Tx that only 3 of the 5 points are adjustable. then i had to "turn on" the other ones. is this o.k. or should i just leave it..
thanks
My tutorials:
Trex 250 Carbon Fiber Tail Push Rod
http://www.helifreak.com/showthread.php?t=238095
FurryTrex is offline        Reply With Quote
Old 04-09-2011, 03:41 AM   #2
Bob O
thanks
All five points of the curves are adjustable. They probably said INH, the ones between Low, Mid, and High right? All that means is that the transmitter will set that point automatically so the curve is linear between the points on both sides of it. Or you can specify a value that makes it linear as well.
Here's what I'm trying to say. The default pitch curve is 0-INH-50-INH-100 right? Since no value is specified where it says INH, the transmitter will make the curve linear between the points where there IS a value specified. So you could make the curve 0-25-50-75-100, and it would be the same as 0-INH-50-INH-100.
Hope this helps.
Warp 360 Spartan Vortex VX1
Bob O is online now        Reply With Quote
Old 04-09-2011, 08:32 AM   #3
FurryTrex
thats was i was thinking.. just needed confirmation.. Thanks alot!
My tutorials:
