Old 04-10-2011, 07:23 PM   #1
firehopper
Default question, what flybarless controllers support 5 blade heads?
I've been looking and the only one I'm sure of is the sk360 and sk720, But its so expensive.
Proud owner of a Hitec Aurora 9
firehopper is offline        Reply With Quote
Old 04-12-2011, 10:23 AM   #2
firehopper
bump, anyone know?
Old 04-12-2011, 07:47 PM   #3
Baddad63
Im not sure but I cant see why it would matter how many blades there were.
Baddad63 is offline        Reply With Quote
Old 04-13-2011, 11:09 AM   #4
cbergen
If you can mechanically set the proper swashplate phasing/timing, you don't NEED the electronic stabilization.
I believe that most, if not all, of the electronic stabilizers allow for electronically setting the swash timing, so they "should" work just fine, but YOU wil have to again set the proper phasing/timing.
Chris D. Bergen
Bergen R/C Helicopters
cbergen is online now        Reply With Quote
Old 05-08-2011, 08:55 PM   #5
BlackTitanium
You can use any flybarless controller, with a 5 blade head.
Before you can fly a multi blade rotor head, you must either phase the rotor head mechanically or electronically.
The question that you meant to ask is "which flybarless controllers have electronic phasing?".
Skookum SK360/720, Mikado and BeastX all have electronic phasing.
Align 3G, Gaui GU365, CYE Total-G, SJGD FS600, Inertia Axiom FBL, Turnigy V-Bar 600 all do not have electronic phasing.
Yes, you can mechanically phase the rotor head and fly without e-stab, but it will not be very fun to do!
The more the wind blows, the more difficult it will become to control.
BlackTitanium is offline        Reply With Quote
Old 05-12-2011, 07:06 PM   #6
heli21
The Helicommand HC3-Extreme and HC3-SX have electronic phasing adjustment. The Helicommand X-base can be updated online to incorporate it.
Rob
heli21 is offline        Reply With Quote
Old 05-24-2011, 12:57 PM   #7
markb
Futaba cgy750 has electronic phasing.
Mark
Logo 600se, Scorpion 5020-450, mini-V, Jive 80HV
Trex 600 ESP FBL, Scorpion 4025-740, cgy750, CC85HV
Trex 450 Vx FBL, Scorpion 2221-10, RJX head, mini-V, Ice 50
markb is online now        Reply With Quote
Old 09-02-2011, 03:06 PM   #8
fofoggy
Hi,
I have a 5 blade head for my trex 500 and have a gyrobot 700. Do I need to set up the 5 blade head with the transmitter first so taht I get the phasing right? And do I then set up the gyrobot 700? Any help on this would be much appreciated. Thanks
Cheers
Paul
fofoggy is offline        Reply With Quote
Old 09-02-2011, 03:44 PM   #9
BlackTitanium
Originally Posted by fofoggy View Post
Hi,
Cheers
Paul
Just looked over the manual.
The Gyrobot does not have electronic phasing.
Yes, you will need to perform mechanical phasing setup with your rotor head and TX.
Then zero all the trim and ATV settings in your radio, and redo the zero pitch trim in the
Gyrobot.
When the wife asks "How many helicopters do you need?"
The answer is always "Just one more!"
Old 09-02-2011, 03:51 PM   #10
Silver-techie
Oooph. What about a Tri-Blade setup on a 450? I use a 2702V on it, and... I don't think it has electronic phasing.
The only problem I think I did have on it, the gyro for the tail was set too high, and it would overheat and freak out on me. But when I turned it down, it seems stable as far as hovering.
Erazor 450 (2801 rx) 2750kv | EXI 450 Pro (2702V rx) FBL Tri-Blade head 3500kv AKE | V450 Walkera (2702V rx) 3950kv Turbo ACE 804 | 4F200 & 4F200LM | V200DQ02 & V200D02 | V120D02 & V120D05 | 250 CopterX | 250 EXI FBL | Genius - WK2801
Silver-techie is offline        Reply With Quote
Old 09-02-2011, 03:59 PM   #11
BlackTitanium
Originally Posted by Silver-techie View Post
"Oooph. What about a Tri-Blade setup on a 450? I use a 2702V on it, and... I don't think it has electronic phasing...."
If the swash to blade grip links are straight up and down, it has electronic phasing.
If the swash to blade grip links are angled, it is mechanical phasing.
Old 09-02-2011, 04:11 PM   #12
Silver-techie
Ahh... kewlio then. Mine are... angled.
The head I got:
xmhobbies trex 450 etc most 450 size heli 3 blade flybarless rotorhead
Old 09-11-2011, 01:47 PM   #13
fofoggy
Hi
Does anyone know what I have done wrong?
I have phased my 5 blade head mechanically and have a gyrobot 700 electronic flight controller.
When I lift of my Heli moves quickly to the left and backwards (as seen when I am standing at the tail of the Heli)
The awash is exactly level all blades are tracked and at 0 degrees at centre stick all linkages same length
Any help would greatly appreciated
Paul
Old 09-11-2011, 04:17 PM   #14
Silver-techie
It sounds like your center of gravity is off.
You'd have to straighten two of the 5 blades out so the heli is faced towards you (tail or nose) holding the inner part of the blade horizontally. That way you can feel if the back or front is heavier, and try to balance it out by moving the battery or adding weights on the back end.
Hope that makes some sense. lil hard to explain.
Old 09-12-2011, 03:08 AM   #15
fofoggy
Thanks.I'll try that and let you know
Cheers
Paul
Old 09-13-2011, 07:44 AM   #16
fofoggy
I have adjusted the centre of gravity but the heli still flies fast left, anyone got any other ideas please?
Cheers
Paul
Old 09-13-2011, 07:53 AM   #17
fofoggy
Question 5 blade head and gyrobot
I hope I have posted this in the right place now.
I have a 5 blade head mechanically phased and a gyrobot 700 on my heli.
I have checked all the usual suspects on set up ie phasing, swash level, links all same length, pitch set correctly and adjsuted for centre of gravity.
My Heli flies fast left each time I lift off (when looking at it from the tail) Has anyone got any ideas why this is happening as I have run out of ideas?
Many thanks
Cheers
Paul
Old 09-13-2011, 08:46 AM   #18
Silver-techie
I suppose the *gyrobot 700* provides electronic stabilization?
Not sure what to advise on that since I'm not familiar with that system. However, I do recall that basically 4 to 5 blades you really don't need electronic stabilization.
I suppose all 5 blades are balanced?
Can you turn the sensitivity down to see if its over correcting?
What class heli are you flying? (450,550, 600, ect)
I don't think I have any advise ta give you, but perhaps keep trying.
Old 09-13-2011, 11:34 AM   #19
fofoggy
Its A trex 500 which I want to ut inside a seaking fuselage. I was thinking that maybe its the gyrobot over correcting, i may tray a normal gyro and see what happens.
Cheers
Paul
Old 03-20-2012, 03:49 AM   #20
fofoggy
Hi Rob,
I am trying to set up my 5 blade head on my trex 500 with helicommand.
I know that if its set up mechanically the links are at 90 degrees and twisted around the
swash.
As I will be setting up with electronic phasing should my links be vertical or do I still need to set them at 90%?
Any help or pictures woudl be greatly appreciated.
Paul
