Old 02-25-2007, 11:07 AM   #1
FBW2000
Default New T-rex, new problems.
Hey guys..
Great site BTW, the finless vids I have seen have helped out quite a bit.
I have been out of heli's for a little bit, and just got back into it with a 450SE, my first venture with an EP heli.
I picked up good components with it (401,dx7,hs65's)...
Had a problem on my 4th flight with the helicopter... I was hovering around with a little foward flight thrown in, and needed to add pitch/throttle quicky... and found myself in my first autorotation...Seems the one-way skipped or something along those lines... motor was still spinning, but no action in the head.
You can hold the head, and turn the large gear to "reset" the bearing to spin the correct way, but the same will result when adding power abruptly. Results.... broken landing gear.
Overall, a very fun heli... still trying to work out the blade tracking, as it seems I dont have the colored tape to use on the blades.
I dont know if its the sleeve, gear, or bearing itself, as I havnt taken it apart yet. Anyone else run across the same problems?
FBW2000 is offline        Reply With Quote
Old 02-25-2007, 11:12 AM   #2
kraaijer
I had the one-way failing on me one time before after a little crash...
it's most likely the bearing itself.
Goblin 630, Vibe 50, trex 500, 450, mcpx v2 and mcpx bl. All fbl of course...:-)
kraaijer is offline        Reply With Quote
Old 02-25-2007, 11:13 AM   #3
Jermo
? when you did and autorotation did you hit throttle hold? (you didn't say), on my Rex the large gear moves CW and CCW with zero issues, If I move the bottom Gear (The AR Gear) CCW both gears rotate, when I move the bottom gear CW only the AR gear rotates.
Does your's do this?
Jermo
Jerry Moore, AMA #878954,TARANIS OpenTX- Pantera 600 FB - Takes a licking and keeps on kicking! KISSAM = Keep It Simple Stupid: Affordable, Maintainable -
Visit Early and often - http://open-txu.org
Jermo is offline        Reply With Quote
Old 02-25-2007, 11:24 AM   #4
JJP9398
I had my one way bearing fail right out of the box. I brought everything outside to run up the rotors and check to see if everthing was ok. Went back inside to work on the wiring came back out to run it up and the only thing the motor turned was the big gear. Went to the hobby shop and pick up a new bearing problem solved.
JJP9398 is offline        Reply With Quote
Old 02-25-2007, 12:14 PM   #5
FBW2000
Thanks guys..
The heli was NOT in throttle up.
I think I am more concerned with the fact that if you hold onto the head, you can "change" the directon of the one way bearing's engagement by rotating the gear.... Dont know if this is normal of one-ways.
All i did when I installed it into the frame, was inspect it.. it was pre-built in the bag. maybe that was my mistake.
Old 02-25-2007, 12:38 PM   #6
FBW2000
edit:
Took out the gears, looked at/cleaned/inspected the bearing.. much better... will try it out again......carefully... haha.
I forgot how much I like the challenge of heli's
Old 02-25-2007, 05:39 PM   #7
FBW2000
well that didnt work..
Still the same thing.. it ONLY happens when I add throttle/pitch quickly... It 'kicks over' the one way bearing so it 'one ways' in the wrong direction.. haha.
Not fun... this thing doesnt auto like my old 60 size gas birds...
I have a new one-way on the way, as well as stronger skids and some blades...
Has this happened to others, where it only happens when adding throttle?
Thanks!
Old 02-26-2007, 03:27 PM   #8
FBW2000
Wll...... fixed it.
In my first post, I said that I hadnt fixed the blade tracking... it was off... WAY off.
I was wondering why I had SO MUCH chop, blade 'noise', woofing (I dont know the right term), in a hover... I didnt think it was normal.
Took a magic marker to one blade, got it tracking perfect... its a COMPLELTY different helicopter!!
I think with the tacking being so far off, it was over stressing the heli....
It sounds amazing at hover now, and I can hear the motor over the blades... Head speed is up a lot as well.
I can NOT get the heli to duplicate my problem with the one-way bearing... and I tried HARD.....
wow I love this thing!!
Old 02-26-2007, 04:02 PM   #9
sleddog7
Whe you get the new one-way be sure to install it in the right direction, if not you'll think THAT one is broken. Good luck!
AMA# 365566 AOPA# 5081747
AMA Turbine # 15130
... Intercepting the Localizer...
Guidance by Futaba 14MZ Heli 2.4 GHz ......FUTABA-- Always Imitated, Never Duplicated
sleddog7 is offline        Reply With Quote
