Go Back   HeliFreak > R/C Electronics Support > Hitec Radios
Hitec Radios Hitec Radios Support
Old 04-14-2011, 06:19 PM   #1
concho
Default ez view screen vanished
i just upgrade to 1.8 (receiver to 2.00) everything was fine i opened the sensor screen and everything was there i took a glance at the ez wiew screens great
then i turn the transmitter of for 30 minutes and powet it on no more ez view the only thing i had. was battery (system sensor )
turn it off again for 8 hours power it back did a screen calibration and the ez view came back
but after another power off on no more ez view i thought maby a bug occured during the upgrade download
so i did the upgrade again i saw the ez wiew once after the seccond download and it vanished again
i dont have the telemetry module i also had a problem with the timer screen when i was in the timer screen and came back to the main screen the timer screen and the main screen where visible at the same time one of top of the other it look like a picasso
and sometime when i power the transmitter i have a blank screen
if someone had this kind of problem feel free to reply thanks in advance
concho is offline        Reply With Quote
Old 04-15-2011, 03:47 AM   #2
A.T.
Originally Posted by concho View Post
i just upgrade to 1.8 (receiver to 2.00) everything was fine i opened the sensor screen and everything was there i took a glance at the ez wiew screens great then i turn the transmitter of for 30 minutes and powet it on no more ez view the only thing i had. was battery (system sensor ) turn it off again for 8 hours power it back did a screen calibration and the ez view came back
but after another power off on no more ez view i thought maby a bug occured during the upgrade download so i did the upgrade again i saw the ez wiew once after the seccond download and it vanished again i dont have the telemetry module i also had a problem with the timer screen when i was in the timer screen and came back to the main screen the timer screen and the main screen where visible at the same time one of top of the other it look like a picasso and sometime when i power the transmitter i have a blank screen if someone had this kind of problem feel free to reply thanks in advance
Please try reverting to V1.06 or V1.07 then upgrade to V1.08.
If upgrade was from V1.06, then the Spectra 2.4ghz module must also be upgraded as a separate item.
Hitec HPP-22 2.4GHz Programmer - Manual, FAQ - How to install & Use Instructions (with screenshots).
ex Hitec USA Support Forum Sticky:
Aurora 9, Spectra Modules & Optima Transceivers
- FAQ & Undocumented Features
- Mixes, Setups, Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline        Reply With Quote
Old 04-15-2011, 03:58 PM   #3
concho
i did the upgrade and i find that the lead nedded to be pushed further in the module
i also call hitec and the told me that is was normal if the ez wiew vanished if the telemetry module was not pluged
thanks for reply
