Go Back   HeliFreak > R/C Helicopters > R/C Helicopter Tools and Supplies
R/C Helicopter Tools and Supplies Tools and Products used with R/C Helicopters
Old 04-15-2011, 10:49 AM   #1
Skiddz
Default Micro extractor set
Anyone got a line on a micro extractor set? I've got a few M2 screws snapped off in an airplane yoke that I need to remove and I'm having a helluva time finding reverse drill bits or an extractor set (or both) to get 'em out.
Thx
-Kevin
Skiddz is offline        Reply With Quote
Old 04-16-2011, 02:46 PM   #2
Mercuriell
Only way I can think to do is use dental drill bit to make a hole then drive in a micro Allen key such as the 0.8 mm, being small they don't usually take much force to get out. If you know a dentist they would probably have a preloved bit they could let you have.
I have used this for getting out rounded set screws
John
Mercuriell is offline        Reply With Quote
Old 04-16-2011, 02:49 PM   #3
chargh
I haven't used these but may work for you.
http://www.micromark.com/MINI-EXTRAC...-SET,8570.html
Trex 450 SP V2, Trex 600 ESP
AMA 943862
This is what happens when I fly!
chargh is online now        Reply With Quote
Old 04-16-2011, 04:05 PM   #4
Mercuriell
Wow! That's a great website - another dent in the credit card !
John
Old 04-16-2011, 10:52 PM   #5
Skiddz
managed to find a left-handed 1/16" drill bit. (1.59mm) Got two of the three screws out no problem. The third is proving to be problematic. Will try some heat and colorful language on Monday.
[bookmarks that website..]
-Kevin
