Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite)
Blade Helicopters (eFlite) Blade Helicopters (eFlite) CP, CX, mCX CX II, CX III. and others
Old 02-26-2007, 09:25 PM   #1
rudderman
Default Carbon fiber blade patch tip
I may have found the perfect carbon fiber blade patch up .I used this stuff i got from walmart thats an epoxy called plastic weld.What i did was apply it on there and built it up. So that i could use my dremel with a sanding drum and shape the tip back up.Then after i did that i weighed both to get them balanced.Then i used a permanant marker and colored it black and its just as good as new.The only problem is that you have to work pretty quick because the epoxy will harden up on ya.The epoxy comes in a all black tube.This stuff is great guys
rudderman is offline        Reply With Quote
