Go Back   HeliFreak > R/C Helicopter Support > Gasser Helicopters
Gasser Helicopters Gasser Specific Discussion
Old 04-18-2011, 02:14 PM   #1
propwashed
Default AR7110 7-Channel DSMX Heli Receiver for Gasser???
Noob to gasser helis. Want to know if anyone has used the:
AR7110 7-Channel DSMX Heli Receiver w/ rev limiter
on a gasser.
I'm trying to get everthing together for a new G-30 and would like some input on this Rx. Will the built in rev limiter work on a gas engine?
What else would be needed for the sensing. (stator gator?)
propwashed is offline        Reply With Quote
Old 04-19-2011, 09:01 AM   #2
Defi Gravity
Default No gator needed
I run a 7100R on my 20, and I just mounted the sensor under the fan shroud . It reads of the EI magnet just fine. Holds RPM very well. I have run this way for over a year and no problems.
Defi Gravity is offline        Reply With Quote
Old 04-19-2011, 10:13 AM   #3
propwashed
Thankyou!!! for the reply. I think I will be going this way as well for my G-30
Old 04-12-2012, 11:42 AM   #4
bmnewland
I will also be using a Spektrum sensor on Radikal g20 as per your setup. Does it make any differnce on the orientation of the sensor. I thought a I read another thread where it would only read correctly in one direction. Thanks.
bmnewland is offline        Reply With Quote
