| ELY.Q - Vision 90 ELY.Q Vision 90 Helicopter Support |
im thinking about getting this bird here soon in the FBL. looking to find out what you guys think of this bird. please let me know the good the bad. anything and every thing you can tell me about the way it flys to the build of the heli thank you for your time...
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. AMA# 982814 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
I'd like to know to, have a second hand opportunity but I'm a bit put off by the quietness of this forum. Is it that nobody owns one or there is zero problem with it?
Ben Goblin 500 IKON w/ gov, Quantum 4115-1200, Hitec 5245, BLS251 DX8, RF6 |
Same here the price is great but why
The heli is good but there is not much said about it because another forum kinda got the ball rolling first and so is a little more popular for this particular model due to more info being shared there!
what do you want to know about the Vision 90? I can't answer any questions about the flybar version as I have not built one! The heli is light (a little less than a TRex) and the frame assembly is very stiff and robust. The build is quite simple but the manual is vague in some areas and there are a few things you should do in a specific order that is not mentioned. for example installing the elevator servo before fitting the second half of the frame if you are using the bellcrank arrangement. It can be done after but is a bit of a Chinese puzzle! I think IMO the quality and design is an improvement on the 50 but each time I replace a part on my 50 it has been improved in some way shape or form so if there is a problem with the 90 (I have not found one yet) and Emails start rolling in to Ely.Q then it will be sorted out quick smart! Two addendum packs have been distributed to wholesalers, one is a few bolts in various places and the other is a one way shaft! the bolts are either longer or shorter for either strength or clearance depending on where they go. The one way shaft is a slightly larger diameter for a more precise fit in the torrington bearing! In the air the heli feels very nice, lite, agile and responsive with solid tail performance but takes a half dozen or so flights to feel smooth and fluid due to it's very hard head dampening! The one issue with such a stiff and light frame assembly is that any vibrations in the primary driveline will be transfered down the boom so balancing the fan, getting the correct engine to start shaft alignment and gear mesh are esentual! ![]() Roll on the weekend, I can't wait to fly it again! Alex
CustomHeliParts/KDE TRex 700N ThunderTiger X50 FBL Ely.Q Vision 90 Ely.Q Vision 50 |
#6 |
Hello Alex,
Have a buddy, that thinks about buying a Vision90 FBL-edition. For this purpose started to read about the subject and found your post Always like, when people unbiased report pro's and con's about a helicopter. After reading in the other forum (the one people sometimes almost killing each-other ), read about someone mentionning 3 to 4 issues to be known, when building this machine as well as some tricks, how to overcome this points.You already stated the issue with the elevator-servo, do you know further points, the refer to ? Read a while in the other forum, but did not find out easely, what the 3 to 4 issues are. Thank you very much for your response - I appreciate, Best Regards, Oliver |
#7 |
Hello Oliver
LOL @ the RR sloughterfest. I am a little biased but I don't see any point in trying to cover up any issues when Ely.Q are onto them as soon as they know! I have yet to own a heli that didn't have a little flaw or two, even the raptors and I still love them! There was a few kits in the first batch that were supplied with a bellcrank spindle that was too short but apart from that I dont know of any other problems. here is a handy pdf I found http://www.elyq.com/pdf/vision90comp...ricks_v90c.pdf that can make life a little easier when building either the 50 or 90. Alex
#8 |
Hello Alex,
What shall I say ? Quick and dirty response and exactly to the point .. many many thanks Buddy of mine first thought about buying an Outrage Velocity-90, but after reading on this *issue* and having some guy on our FF flying one (shall I say crashing it frequently?), he definetly favors the idea to go with the Vision-90. As maybe it will be myself to assemble his Vision-90 FBL, I'm naturally interested in knowing as much as possible from experienced people that already have some expertise about this model. All I can promise is, if I find some things or have some procedures making life easier, I would share it with you guys and try to give back, what you guys already shared with me Best Regards - many thanks, I appreciate, Oliver |
#9 |
I own 2 ely q 90's fly barred and fbl. The kits are great for the price I would say equal to if not better and beefier than align. Like all kits there are a few very small build issues but nothing big. There are some pilot build tip on the ely q website. This heli has some very nice design thoughts put into it. It's one of the lightest feeling 90's on the market.. I woudnt hesitate to buy another kit myself well worth the money IMO... Hope this helps feel free to contact me if you guys have any more question....Call me direct 502 802 8690 no problem!!!!
TEAM To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by helinewby; 05-03-2011 at 05:44 PM.. |
