| 550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
I want to build a 550e. I have a 450 PRO and would like to step up in size. I plan on running a BeastX FBL. I love it on my 450!
What would be the cheapest way to buy if I plan on upgrading all the servos and electronics? |
Here ya go, http://grandrc.chainreactionweb.com/...duct_info.html
Just select the items you dont want included then add it to your cart to see the reduced price.
T-REX 700E VBAR T-REX 450 PRO BEASTX |
+1 grandrc build-a-combo
nothing wrong with stock electronics just add a ccbec pro and a beastx
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
+1 HAMSTAR 550 + BEAST X + CC BEC PRO = NO WORRIES
#6 |
The GrandRC build your own combo looks like a decent deal if you want to start swapping pieces out. If I were buying another 550E right now I would probably go that route.
A Main Hobbies |
#7 |
Im actualy thinking to buy one for myself too and i have seen T550 FB S.COMBO for about 650 $ so its only 150$ more that from cgrandrc
with equipment worthet at least 250$ Ofcource buying only kit is great deal but for those who want "plug'n'play" option,IMO better to buy whole superior combo and just get rid of stock parts right away-best bang for buck. BR Martin P.s Im flying with flybar,so that cut the cost also.
LOGO 600 SE Vbar5.3Pro -700 mm LOGO 500 SE Beast X -600mm MCPX BL |
#8 |
Check out performanceplusrc.com. best price I've found and where ill be buying my next heli. I've been buying my parts there
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. A Main Hobbies/ProTek R/C Field Rep RotorWorkZ ):> To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#9 |
Check also here:
http://www.century-rc.com/ecs/produc...07&kind_id=727 You can find something interesting too
#10 | |
The straight 550 3G package is Total: USD 851.00 if you select EMS and I'm sure you'll get it for less in the US. Edit: It is most likely an attractive deal for those not in the US.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. SAB Goblin 700 - CCHV120 - BEC Pro - AR7200BX - TM1000 / T-Rex 450 Sport - 3GX - Tarot head / 450 Pro - GT5 - Tarot head / T-Rex 550 V2.1 - CC100 - BEC Pro - AR7200BX - TM1000 / |
#11 |
+1 for Kirk at Performanceplusrc.com. He is a quality guy who runs a great operation. Tell him what you want to do and he will work with you.
MA Furion 450 Mini vBar │ Xcell 3595/CC-50lite, HS 5065³, FT9257¹ T-REX 250se BeastX │ Scorpion 2206-3900/CC-25, HS 5065³, 5084¹ MCP x |
#12 |
I did't say it's cheap
As i said before,for me,best to buy whole T550 S.combo and just sell all electronics. But it's personal choose ofcourse. P.s.Almost every product find its costomer-vide turnigy lipos from ebay ![]() BR
#13 |
#14 |
The BeastX can be used with a Spektrum satellite so you don't need the main rx unit. Problem is on a bigger heli like the 550, running only one satellite is risky. There is supposed to be an adapter coming that will allow the use of two satellites, but it hasn't hit the shelves yet.
