Old 04-24-2011, 02:58 PM   #1
dbennettya
Default Switching to Bocca grip bearings
Hi all,
While troubleshooting a shake and wobble problem I found two B version grip bearings that were notchy after only about 30-40 flights.
The root cause of my wobble problems turned out to be a split in my mainshaft that was almost impossible to see with the head attached.
I did a bunch of research and finally found the 10 pack of Boca bearings. The part number is:
#RCTPX-MR681-XZ/W1.12 and the shipped cost was $19.99 so there was a price increase but not bad at ~ $2 each.
Good Luck, Don
dbennettya is offline        Reply With Quote
Old 04-24-2011, 04:23 PM   #2
croc
I use the same pack (10) without any problem with "B" grip
croc is offline        Reply With Quote
Old 04-24-2011, 08:10 PM   #3
bradharvy
Originally Posted by dbennettya View Post
Hi all,
Good Luck, Don
I have a set of ten, they are 1.12 not 2.0 thickness, is that ok? I think they are supposed to be like 4.0x1.5x2.0 ?? noticed that and have not used them, have t-rex in now myself.
And I'm not saying that yours are 1.12 but would like ta know. I ordered from the same link a bunch of us did!!
bradharvy is offline        Reply With Quote
Old 04-24-2011, 08:11 PM   #4
bradharvy
Sorry my bad, same part #...
Old 04-24-2011, 08:12 PM   #5
dbennettya
No, the correct size is 1.5x4.0x1.12mm for the A & B stock grips. The Walkeras measure 1.133m and the Aligns measure 1.2mm both of which are the wrong size.
Don
