Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mCX
mCX Blade (eFlite) Micro CX Helicopters Information and Help
Old 04-25-2011, 06:07 PM   #1
BigDave76
Default DX6i settings with MCX2
I searched, and cant find settings for the DX6i and MCX2??? Please help.
Blade 120SR, RKH'd out, with custom black carbon fiber canopy, Blade MCX2 w/Microheli upgrades, Syma Fairy, T-Rex 450 Clone, DX6i with custom orange backlight.
BigDave76 is offline        Reply With Quote
Old 04-25-2011, 06:25 PM   #2
Pfloyd
Here ya go!
Set up List
Model Type-heli
reverse-N(all of them)
Swash Type-90*1 servo
D/R Combi-D/R SW: ELEV
Adjust List
Be sure Elev D/R switch is in the 0 position to enter the first set of numbers.
AILE 0 100%-20%
ELEV 0 100%-20%
RUD 0 100%-20%
Now flip the Elev D/R switch to 1 to enter the next set of numbers
AILE 1 100% +15%
ELEV 1 100% +15%
RUDD 1 100% +15%
GYRO
RATE SW-GYRO
0:<100.0%
1: 0.0%
Throttle CUR
NORM +POS L 0.0%
pos 2 30.0%
pos 3 45.0%
pos 4 60.0%
pos H 75.0%
STUNT pos L 0.0%
pos 2 40.0%
pos 3 60.0%
pos 4 80.0%
pos H 100.0%
HOLD -0.0%
MIX 1
RUDD> ELEV ACT
RATE D +31% U +36%
SW ON TRIM INH
MIX 2
INH
Syma S107-Syma S109-Syma X8C-Syma X8G-Syma X5HC-Syma X5HW-Mini Orion-ProtoX-Syma X5C-1
USAF RETIRED 1968-1988 Vietnam Veteran
Pfloyd is offline        Reply With Quote
Old 04-25-2011, 06:49 PM   #3
BigDave76
THANK YOU PFLOYD!!!!!!!!!!!!!!!!!!!!!
Old 04-25-2011, 07:42 PM   #4
Pfloyd
No problem....
Old 05-16-2011, 01:23 AM   #5
J-son600
Gonna have to try these settings. Bound my mCX to my DX6i tonight, changed nothing but model name. Flew very nice with no programing, be interesting to see how she does with this set up.
Blade mCP X BL - The 3D "beater"
T-Rex 250 - Current garden defense bird. LOL
T-Rex 450 Pro 3GX "Scale Airwolf", WIP
Kyosho Nexus 30 - "Damn I can't believe I learned on something like this........
J-son600 is offline        Reply With Quote
Old 05-16-2011, 02:40 AM   #6
scotsoft
Thanks for posting those settings, I am going to try them right now
mCX, mCX S300, mCX2, mCX Tandem, mSR, 120SR, CX2, NE Solo Pro 2, NE Bravo SX, mQX, V911, V929, V939, Hubsan X4, Turnigy 9X, DX6i
scotsoft is offline        Reply With Quote
Old 05-16-2011, 05:10 AM   #7
Jonne_5
Do you know if this is the same setup for mine spektrum DX7 and Trex 450 pro?
Jonne_5 is offline        Reply With Quote
Old 06-21-2011, 08:19 PM   #8
Ron34238
Phloyd - how about your Dx6i settings for both the MCX and the Tandem Rescue?
BL mCPx (HP05 motor/SR120 tail), Blade mCP X v2 (stock), Blade 130X, Blade mQX, Blade nQX
Blade mSR X, Blade mSR, Blade mCX2, Blade mCX, Blade Tandem
DJI Phantom w/AR8000 & TM1000, DX8, Phoenix Sim, AMA# 976697
Ron34238 is offline        Reply With Quote
Old 06-22-2011, 12:29 AM   #9
Pfloyd
Actually, I don't have a DX tx. I just google the settings for bigdave.
Old 06-22-2011, 10:17 PM   #10
megawhacker
megawhacker is offline        Reply With Quote
Old 06-23-2011, 10:58 AM   #11
Ron34238
Thanks, Pfloyd. After receiving you reply, I then googled and found the same ones you came up with.
Old 06-24-2011, 06:36 PM   #12
BigDave76
Thanks PinkFloyd, I actually had to adjust the throttle setting... the settings you provided compinsated perfectly for the "clack of death" I can turn in both directions at full speed really tightly with no issues what so ever, but the throttle settings are a bit harsh. It cuts the blades out at about mid stick. I adjusted the throttle curve to respond like it did fresh out of the box.
Old 06-24-2011, 07:07 PM   #13
Ron34238
BigDave -- did you just get around to trying these out now?
Old 06-25-2011, 10:47 PM   #14
BigDave76
I tried PF's settings the day he offered them to me, but didnt like the throttle settings, and quickly adjusted them after I noticed how harsh the curve was.
Old 06-26-2011, 07:35 AM   #15
Ron34238
Would you mind sharing the current throttle settings you are using?
Old 02-12-2012, 11:01 PM   #16
davidvm3
how about now? big dave?
Also, what does this do?
MIX 1
RUDD> ELEV ACT
RATE D +31% U +36%
SW ON TRIM INH
Lastly, I am a bit of a noob obviously. So which switch changes to stunt with these settings?
EDIT: NVM I got it!
Thanks,
David
davidvm3 is offline        Reply With Quote
Old 02-12-2012, 11:21 PM   #17
Pfloyd
BigDave hasn't been on here since last June......(:
Old 05-01-2012, 08:55 PM   #18
Mini Tmaxx
Here ya go!
Set up List
Model Type-heli
Adjust List
AILE 0 100%-20%
ELEV 0 100%-20%
RUD 0 100%-20%
AILE 1 100% +15%
ELEV 1 100% +15%
RUDD 1 100% +15%
GYRO
RATE SW-GYRO
0:<100.0%
1: 0.0%
Throttle CUR
NORM +POS L 0.0%
pos 2 30.0%
pos 3 45.0%
pos 4 60.0%
pos H 75.0%
STUNT pos L 0.0%
pos 2 40.0%
pos 3 60.0%
pos 4 80.0%
pos H 100.0%
HOLD -0.0%
MIX 1
RUDD> ELEV ACT
RATE D +31% U +36%
SW ON TRIM INH
MIX 2
INH
Thank you! Worked perfectly for my mcx2. Love flying it.
Blade 450 3D, Blade 120SR, Blade MQX, Blade MCX2, Blade Scout, Heli-Max 1sq Quad, Griffin Heli, Traxxas QR-1, DX6I DSMX w/ blue backlighting.
Mini Tmaxx is offline        Reply With Quote
Old 05-01-2012, 08:56 PM   #19
RoboHeli
MIX 1
RUDD> ELEV ACT
RATE D +31% U +36%
SW ON TRIM INH
Except for this part. This is what you do for the MSR to disable the automatic mixing of elevator and rudder that the 5-in-1 does for you. Why is this here in the MCX2 settings?
RoboHeli is offline        Reply With Quote
Old 05-06-2012, 09:42 PM   #20
seldredg
Default DX6i setting question
I have a new MCX2 and a DX6i, set to whatever the default is when you bind it. Works OK so far for what I'm doing using the stock pushrod position. (I just changed to the longer setting but haven't flown it yet (waiting for glue to dry). What is the effect from the default DX6i settings of the settings provided here?
And in particular, what is the affect of this setting:
MIX 1
RUDD> ELEV ACT
RATE D +31% U +36%
SW ON TRIM INH
Scott
seldredg is offline        Reply With Quote
