Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 425
Hurricane 425 Discussion and support of the Gaui Hurricane 425
Old 04-29-2011, 06:54 PM   #1
torana74
Default X4 FES official
Looks like it's finally a factory direct
In fact, before this, the factory has been phasing out the X4 FES's parts to "modified product " for sale in the name of the first action of the. Today, it is to do a total order, the scattered parts together, and inserted the key two fuselage sides, as the X5 like miniature ... X4 gives great persuasive.
With no balancing pole current popular style of the main rotor head, the pan-425mm main rotor electric helicopter specifications, lithium polymer battery factory recommended specifications for the 6S 2100 ~ 3000mAh.
Sales model will use the package approach, with a brushless motor is slated to have GM504 (Scorpion HK-3026) and GE-602 66A ESC. Servos and GAUI MINI V-BAR-axis gyroscope has not been determined whether the subsidiary be sold in the suite.
Market is expected in August 2011, the reference price is determined.
GAUI X7, GAUI X5 all vbar.TT 12S Hurricane 550 beastx
GAUI
Field Rep, Team Empire Hobby
torana74 is offline        Reply With Quote
Old 04-29-2011, 07:43 PM   #2
Jerrymac
Hmmm, it seems a little odd that they designed a new frame with direct to swash servo mounts, and still used the old " 4-gear" drive system.
I would have thought that they would have used one similar to the X5. Of course, it is a good thing for us 'cheap guys', that were hoping that they will continue selling the 425 plastic framed kits for a while longer. At least most of the parts are probably the same on that X4 so parts should be available for a while.
I don't need the latest and greatest. I just need more time to fly what I have.
Align 450 Sport V2, Gaui 200, Gaui 425 x 2, "HeadHunter 500, Gaui 550, all Flybar'd
Jerrymac is offline        Reply With Quote
Old 05-10-2011, 06:34 AM   #3
torana74
Some pics from the Beijing Model Show
Vas
GAUI
Old 05-10-2011, 11:40 AM   #4
nexgen
I cant wait til the X4 stuf is stateside.
Gaui 200 •Gaui 550 •Gaui X5
BeastX Castle Scorpion Hyperion Spektrum JR
The Front Porch, Nexgens Lounge
nexgen is offline        Reply With Quote
Old 05-10-2011, 01:53 PM   #5
fusionsx00
Some of it is
fusionsx00 is offline        Reply With Quote
Old 05-10-2011, 06:46 PM   #6
hfenn
That may very well be my first FBL heli (oops, other than the mCPx I already have, lol)!
hfenn is offline        Reply With Quote
Old 05-11-2011, 07:28 AM   #7
gpraceman
Originally Posted by fusionsx00 View Post
Some of it is
How's that X4 head working on your 425?
Walkera V120D01
CopterX CX450 SE V2
Gaui 425
gpraceman is offline        Reply With Quote
Old 05-11-2011, 04:03 PM   #8
fusionsx00
Freaking awesome,
looks good, flys great
lower than the x5 fes
better geometry to swash, nothing bad to say
Old 05-11-2011, 05:04 PM   #9
gpraceman
Freaking awesome,
I have one on the way, so that is good to hear. Anything special to do to fit it to the 425? Use the grip to swash links that came with the 425 basic kit?
Walkera V120D01
CopterX CX450 SE V2
Gaui 425
Old 05-12-2011, 02:45 AM   #10
fusionsx00
Nope, the x4 has grip arm extensions, they stick out quite a bit, then go to the swash
Its a pretty much bolt on install, using the 425 swash
I got the complete head, it has a main shaft, yoke,grips,grip arms, swash lock arms, assembled
it is alot shorter
Old 05-12-2011, 03:27 AM   #11
fusionsx00
Im getting that frame
Its in the works, im not sure how fast, maybe a few months
Old 05-27-2011, 04:51 AM   #12
ChibiHeli
from the picture, it's very likely X4 is using mini size servos, like t-rex500, not standard size servos like 425?
sorry if I'm wrong, and sorry if this has been covered before
ChibiHeli is offline        Reply With Quote
Old 05-27-2011, 06:01 AM   #13
fusionsx00
Man glad I did not pay for that yet
Old 05-27-2011, 06:24 AM   #14
ChibiHeli
well, not an assumption anymore, I found out that you could read the servo model number if you stare at it long enough... that's a SAVOX SH-1250MG, that is indeed a mini size servo.
Old 05-28-2011, 07:22 AM   #15
ChibiHeli
I met local GAUI dealer today and he confirmed that, tail servo is SAVOX 1257MG
