| Aerial Videography and Photography Aerial Video/Photo from R/C Helicopters |
#21 | |
As for your 2nd answer. I thought that I would be able to "re-use" the HC at any moment I decide to switch it on again. Or better, if I am steering for myself for some time, feeling I am loosing control I can let go of the aileron/elevator stick and the HC will level the heli. I understood this even in case I have done a looping or something, is that nor correct ? I could not find this in my manual. Not that I intend to do such (for a long time) but still. regards, Ruud |
#22 | |
It takes up to 10 second for full accuracy when the unit is turned on and I believe but don't know for sure that the heli should be level during this period. It thats correct you can't just turn it on for a save when your already in deep poo poo. If its already on and you get in trouble I understand you can just release the controls and it will right itself unless you have just completed multiple stunts. This is in referance to the 3D or rigid version as the standard 3 version will not tolerate any stunt moves. |
#23 | |
If I have used and experience with my HC, I will be able to tell all here, how it works. And thanks Gary, for those pictures. Very clear and nicely done. I will consider changing my setup, although I am afraid that my heli will then decline even more to the back. CU Ruud[/quote] |
#24 | |
Guess inertial based system would be similar as above, just much more accurate... best in this case would then be inertial mixed with IR... of course for this only purpose. |
#25 | ||
#26 |
double post...
-- Gary To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#27 | |
Just having a 3-axis gyro system is not enough, I think. What is also needed are accelerometers in each axis. That way vector velocities can be calculated and corrections applied to zero out those velocities. -- Gary
#28 |
well yes, first I think those buildings and trees etc - even hills have no big influence if enough far away, I am flying just besides a railway bridge (less than 100m) and several high buildings (about 500m) and my AP2000 does not care at all.
This cal function, true it remembers this, but then of course you cannot turn 180 and think it's still leveling horizontal, for AP I guess you are fine, for aborting 3D is of course not useful. That what I have understood. Definitely accelrometers are needed for the gyro system, but still for a 10 min 3D flight and then aborting with emergency switch to horizontal, this accuracy would be almost impossible to pay ... and actually for this special purpose most of the pilots are fine if the heli is "just about" straight, for this IR is perfect.
*** fly more *** |
#29 |
Well, for AP/AV applications you aren't doing 3D at all, much less for 10 minutes.
#30 |
yes I fully agree with you, this is why I wrote "for this special purpose" (3D), IR does the job quite well as I experienced.
#31 |
Hi,
A question for Gary Evans. I understand how you switch modes on the HC by assigning the flight mode switch to AUX 2 but what I don't understand is how does this affect the throttle curve and pitch curve. I am interested in scale so am not to worried about flying in normal mode on the tail gyro but wonder how is the throttle/pitch designated. Hope you can understand what I am trying to say. |
#32 |
Throttle and RUDD are not pluged into the AP2000I
Thank god for that , I guess the guys that built the thing knew where the limits were... I have one hooked to the TREX600N... Get the Trims right!!! Set the Gain PIT / Aile /elev somewhere around 60%.. Your good to go.. I had my set to 30% when I started,,, that killed pitch down to 4.5 Degrees,, I kicked it up to 60% and 11.5 Degrees. And I sitll had 30 % to go,,, But at 60% I got a slight Bog on the OS 50 Hyper,,, But Def,,, a rocket ship,,, My T600E kicks off faster that D13 Rocket ,, ![]()
Personal Information security buff. FTC IC3 ask me how. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
