Old 03-04-2007, 12:19 AM   #1
coolbreeze8
Default dx 7 expo ?
there is a pos. an a neg. value on tx with a neg. # value i will tighten up the feel around center stick is this true
thanks Dewey
coolbreeze8 is offline        Reply With Quote
Old 03-04-2007, 07:31 AM   #2
Jermo
True, Expo is awesum. for our radios use positive Expo. I use 20% expo on the Aileron/Elevator channels set on the swash menu (if you have a ccpm bird otherwise set on the channels direct).
Jermo
Jerry Moore, AMA #878954, IRCHA #2988
Pantera .61bbc - Takes a licking and keeps on kicking! , Trex 500CF, MCPX V2 Readyheli BL
Ok, you can fly...but can you HOVER??
KISS = Keep it simple stupid (to maximize fun and reduce costs!)
Jermo is online now        Reply With Quote
Old 03-04-2007, 12:05 PM   #3
coolbreeze8
Thanks Jermo Im running a neg. -30 on expo. feels pretty good your videos were a big help
thanks Dewey
Old 03-04-2007, 04:58 PM   #4
DavidH
Dewey,
Negative expo on your radio increases the sensitivity around center. Usually most pilots prefer a softer feeler around center and would prefer positive expo.
You might want to make it softer and it would be less touchy around center stick.
Note: A negative (-) Expo value will increase sensitivity around neutral, and a positive (+) Expo
value will decrease sensitivity around neutral. Normally a positive value is used to desensitize
control response around neutral.
David
DavidH is offline        Reply With Quote
Old 03-04-2007, 11:12 PM   #5
coolbreeze8
Davidh
seems odd but I was looking to thighting up the feel around center stick it seems like most tx. your in the pos. side of the value to thighten up the feel wasn't sure i read this right in the manual Jermo set me straight on expo. values this morning Maybe if igot the slop out of my swash i could go into the pos. side of expo. LOL
thanks
Dewey
The older I get the faster I used to be
Old 03-06-2007, 08:22 PM   #6
Danal Estes
Just for completness in this thread: JR (and Spektrum) are OPPOSITE of Futaba when it comes to expo! Positive expo softens the stick around center on JR and quickens the center on Futaba!!!
This has caused many a crash when pilots help each other set up. ALWAYS visually verify the surface movement, prior to flight, to see if you have what you want (perhaps even dial in an exagerated amount for a moment to more easily see the change, then set back to a realistic value for flight).
Trex 700E - SuziHans,V-Bar,JR8717/BLS251,X-Era 4030/3Y-460,12S Rhino 4900; SH frames are ~1 Lb lighter than Align 700E kit
Trex 700N - 7100R/JR8717@8V/GY611
About a dozen more, including 2xTrex 500 - 1 V-Stabi/6S, 1 Flybar/5S,GY770/DS3400G
Danal Estes is offline        Reply With Quote
