Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 30/50 > Titan X50
Titan X50 Thunder Tiger Titan X50 Helicopters
Old 05-03-2011, 10:57 PM   #1
Reever45
Default Easiest FBL setup for X50?
Ok have my Beastx already ordering heli end of the week, what i want to know from those that may have done it which head is the most straight forward to use (pnp) RJX,Outrage,Compass,Align,or Tracx although it looks like its made by Compass.
Reever45 is offline        Reply With Quote
Old 05-04-2011, 03:48 PM   #2
kiwibob72
Why not just wait a few months and use an original TT X50 one, as from ramblings all over the forums, it looks and sounds like that option is on the way soon!
kiwibob72 is offline        Reply With Quote
Old 05-04-2011, 03:49 PM   #3
currera501
Hello Reever45 my name is Mike. I just got finished with my TTX50 and with the fly bar. I like the way it flies. When I go flybarless I am going to go with the RJX head man that thing looks bada$$ .It is polished and it just looks easy to setup and all of that. But that js just me.
currera501 is offline        Reply With Quote
Old 05-04-2011, 05:27 PM   #4
Reever45
Lol i guess what my wife says is true that i am impatient, and i don't have another gyro layin around although i guess i could use the microbeast as a the gyro. But nah i think i would just as soon use one of the heads available now,i was just looking for the one that took the least amount of mods or fiddling around with.
Old 05-05-2011, 02:34 AM   #5
NitroAl
I would remove the flybar and flybar control links, lock the seasaw in the head square with the main shaft, drill and tap the washout base to lock it on the mainshaft with two grub screws, use the standard links from swash to mixing arm on the locked seasaw and from the mixing arm to the grips and fly that with your beastX until the TT one is out!
Works a treat!
CustomHeliParts/KDE TRex 700N
ThunderTiger X50 FBL
Ely.Q Vision 90
Ely.Q Vision 50
NitroAl is offline        Reply With Quote
Old 05-05-2011, 06:14 AM   #6
bshinn
Put a REX600 head on my Titan SE, Not flown it yet, but couldn't be happier with build quality or looks.
It's a NICE piece of CNC machine work.
bshinn is offline        Reply With Quote
Old 05-06-2011, 05:35 PM   #7
Reever45
Thanks for the input guys, but after careful consideration and not wanting to worry about what or whatnot would need to be modified i have a Fury 55 FBL headed my way so i guess im good to go.
Thanks again
Old 05-06-2011, 10:45 PM   #8
bshinn
Thanks again
Kind'a feel vindicated!
Old 05-07-2011, 12:25 AM   #9
NitroAl
Good choice of head! The Fury head is a work of art in TRUE cnc high grade alloy!
No cnc or very little in the TRex parts. Watch the swash driver links don't hit the swash at full cyclic, if they do use the 500 arms on the 600 links.
Ely.Q Vision 90
Ely.Q Vision 50
Old 05-07-2011, 09:35 PM   #10
bshinn
Are you saying the TREX head is cast or forged, because that shure looks like several chuncks of machined Alu to me.
Thanx for the tip for the arms, I'll check that closley when i set it up. I did notice the links don't fit the TT balls on the swash. The phasing arms fit fine, but the links to the blade grips are loose.
