Old 05-08-2011, 11:18 AM   #1
1800BIGK
Default Beastx on 2S
Getting ready to do a build with AR7100R receiver and Beastx with HV servos, is there anything I need to worry about or adjust when running a 2S lipo? I saw this post on rr and just wondered if it still applies.
http://rc.runryder.com/helicopter/t619223p1/
1800BIGK is offline        Reply With Quote
Old 05-08-2011, 01:55 PM   #2
nexgen
I think that is old news, currently I am not aware of any issues setting up like you are planning on doing.
Gaui 200 •Gaui 550 •Gaui X5
BeastX Castle Scorpion Hyperion Spektrum JR
The Front Porch, Nexgens Lounge
nexgen is offline        Reply With Quote
Old 05-09-2011, 11:47 AM   #3
nwmtech
Nope. I run all mine on straight 2s.
nwmtech is offline        Reply With Quote
Old 05-12-2011, 09:36 PM   #4
jasonr
v2 says right in manual its 2 cell lipo ready out of box
trex 600 esp- stretched, 12s scorpion 4025 630- hv 85, trex 550e microbeast, flybarless-ice 100-553 edge fbl blades-scorpion 4025-1100, dx7 SE, mcpx stretched- bone stock
jasonr is offline        Reply With Quote
Old 05-12-2011, 10:19 PM   #5
Helico-pteron
Run an extra power supply to the SYS port and you'll be fine.
As noted above, the MB will run on 2S lipo unregulated. The issue is that only the elevator lead supplies power to the cyclics.
Helico-pteron is offline        Reply With Quote
Old 05-12-2011, 11:43 PM   #6
Bob O
Member
Elevator and one other? I have a third lead supplying power through the Sys port.
Bob O is offline        Reply With Quote
Old 05-13-2011, 09:00 AM   #7
Helico-pteron
Yes, both ail and ele carry power.
With any single line Rx, elevator is the only power source.
Old 05-14-2011, 07:00 AM   #8
Mikey D
Hi, could you further expand on what you mean about this being old news? Are you saying this was addressed in a SW update? I am getting ready to install on a Rave ENV with all HV servos including tail, I'm using Beastx Ver 2
It sounds like people are saying 2S is fine and to add a second Pwr Source?, but what about the high current demands of HV servos?
I've read the sticky on high current setups about 10 times.
I was planning on a Kiwi Regulator
Do I not need to use the regulator with HV servos on Cyclic and tail, and wire straight out of the manual? I am using JR8917HV Cyclic and OutRage BL9188
Mikey D is offline        Reply With Quote
Old 05-14-2011, 11:37 AM   #9
nwmtech
It's my personal opinion that people made a big deal out of something that didn't need to be. All of my 50s and 90 have ran straight 2s and nothing else. Even nitros so that's one more servo. I wire all mine the same... Dual power leads out of my power source (BEC or failsafe switch depending on N or E heli) . One power lead goes to a port on the RX and the other goes to the SYS port on the beastx. Those combined with the AIL/ELEV patch cables provide plenty of current carrying capabilities and redundancy.
