Old 03-06-2007, 07:36 PM   #1
tigermike82
Default DX6 not recognizing low throttle
When I tried to reprogram my align 35 ESC with my DX6. I start with the throttle high, listen for the beeps for it to recognize the high throttle, move it to low throttle and nothing.
When I plug in power, the ESC beeps like the throttle is not in the low spot. I have checked the obvious. What next?
Don't tell my wife it crashed!!
tigermike82 is offline        Reply With Quote
Old 03-06-2007, 08:12 PM   #2
z11355
what 'obvious' stuff did you check?
did you verify that the throttle trim was set to either neutral or even full-low?
did you mess w/ the throttle channel low-end ATV?
z11355 is offline        Reply With Quote
Old 03-06-2007, 09:20 PM   #3
tigermike82
trim was set at 0 and I tried sertting it to full low & nothing changed.
I am not sure what you mean by throttle low end ATV
Old 03-07-2007, 10:21 AM   #4
Paul Hinz
Do you have a throttle curve set in the radio or is the radio in throttle hold.. The throttle curve has to be a straight line from 0 to 100 to set the ESC.
Paul
Paul Hinz is offline        Reply With Quote
