| BeastX FBL System BeastX FBL Flybarless System Software and Hardware Support |
#41 |
Great vids ! as always
maybe something worth mentioning in step J and K is the position of the head important ? like 90 degree from the boom ?
E7 - MSH Brain- HW 120HV- BLS 451-693's Protos 500 stretch- Robird31- JR3400- BLS251-470's Building- DIABOLO - Brain - MKS servos |
#42 |
For step J the blades should be parallel to the boom. For K the position doesn't matter. If you have done the previous steps correctly, the min and max pitch degrees should be the same regardless of head position.
GAUI Field RepbeastX│Team Empire Hobby Gaui 200 •Gaui 550 •Gaui X5 BeastX Castle Scorpion Hyperion Spektrum JR To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#43 |
Just to say to Helico-pteron thanks for the thread and to Nex for the great videos. Just got one of those new Spektrum Receiver/Beast combos and it helped me understand the setup a lot - its the same basically - you just get a built in 7 channel Spektrum DSMX receiver too. Cheers guys
I always wanted to fly a model helicopter - I still do! Trex 250SE - Trex 500ESP FBL - Trex 500 - Trex600ESP FBL-Trex700E F3C |
#44 |
Hey Rob,
Just went through the videos last night. Thanks so much for this great resource. Setup makes so much more sense now that you have explained it. You even answered my question about skipping through the setup points in your final video - absolutely perfect! - Sean
#45 |
nexgen amazing tutorials as always you are such a great ambassador to this wonderful hobby!
________________ Gaui - MSH - Scorpion - JR - Byron - OS - MKS - Savox - Edge - Spin - Rails - Lynx - Gensace - Skookum - KBDD www.irchc.com |
#46 |
Great tutorial video Nexgen, i'd definitely learn quite alot from watching your video a few times and getting it setup on my Trex500 EFL Pro.
#47 |
Im glad you find them useful. It was fun making them
#48 |
These are perfect.... I am such a visual learner..... I set up my 3G using YouTube videos and tomorrow I'll be setting up my beastx on my 450 sport tomorrow..... Thanks Nexgen sutty and others.....
Geoff
GOBLIN 500 BEASTX, BLADE 450X, [COLOR=purple]HK500GT 3G, TREX250 PRO, MCPX BL, 130X HP08 |
#49 |
Excellent videos Nexgen and Ivan!
As a curious noob, these were done on V2 correct? Is there anything majorly different in V3 that warrants updated videos?
Jesse Mc. - Novice pilot, AMA member B450X +IKON +ICELite50 +13T gear | Flights=084 Crashes=002 MCPX v2 - sold |
#50 |
On step G, toward the end where you are setting zero pitch with a screwdriver or long rod, are you just eyeballing the screwdiver next to the shaft? I know a lot of people use a gauge here, but I like the idea of setting zero pitch relative to the shaft this way because it's very quick and easy. Is the accuracy ok using this method?
#51 | |
Warp 360 Spartan Vortex VX1 |
