Old 05-12-2011, 10:46 PM   #1
smaze17
Default Maiden today with Beastx went flawlessly
Awesome maiden today! thing is rock solid even with 25 MPH winds today
I'm not used to my helis being this sensitve.....it reacts to every slight input but not in a bad way.
I can see upgrading my 700e to a Beast real soon!!!
S
ID:	227417   Click image for larger version
ID:	227418   Click image for larger version
ID:	227419   Click image for larger version
ID:	227420   Click image for larger version
Compass 7HV / AR7200BX / CC ICE2 80HV / Align 700MX / Edge 693FBL
Trex 700 Pro / iKON / CC EDGE 120HV / Align 800MX / 3G 700's
KDE Blinged Blade 130X
smaze17 is offline        Reply With Quote
Old 05-12-2011, 11:06 PM   #2
tmry
Nice! I want FBL but I think I'm going to wait and see if I get a bonus and build my Rave 450 FBL.
If I had my ice 50 strapped to the bottom like that, I'd find a way to smash it straight away. Of course that's my luck though. With that KDE battery plate there's plenty of room under the tray.
tmry is offline        Reply With Quote
Old 05-13-2011, 12:49 AM   #3
fastturtle
I had my satellite receiver in the same place your ESC is and it almost got crushed when my landing gear broke. Keep us posted on the maiden. Have fun…
Chris.
Fastturtle-Chris - Trex 450 Pro FBL, Align FBL head, Microbeast, Sat. only, Ice lite 50, S9257 mks metal gears. / Spektrum DX7 / Phoenix V3 Sim/EXI 450
mCP-X-microheli frame,swash-tail boom mod.
fastturtle is offline        Reply With Quote
Old 05-13-2011, 04:59 AM   #4
TRex888
Strap it higher up the side to protect it.
TRex888 is offline        Reply With Quote
Old 05-13-2011, 10:51 AM   #5
smaze17
Do you need to strap down the Beast like you did?
Old 05-13-2011, 12:07 PM   #6
sarpilot
First flight make sure swash is level before you pull it off.... control check slow return to center is normal for swash but make sure level before liftoff.... gl!
"It's not the crash so much as the sudden stop"
Alees Rush 750, Compass 7HV, Compass 6HV, TRex450Pro, Blade MCPX, bunch of other junk in boxes
sarpilot is online now        Reply With Quote
Old 05-13-2011, 02:36 PM   #7
TRex888
I found performance better with it strapped down firm, but I have no idea what other people do. I always worry about gyros flying off the pad when inverted.
BTW: I got rid off the KDE mount, found vibration being transmitted from the anti-rotation pin into it. The slot was too large and being made of metal probably made the vibs worst. Mine flies much better with the original stock plastic.
Old 05-13-2011, 07:44 PM   #8
smaze17
Perfect maiden guys!!!!
I don't think I will ever go back to flybars
S
Old 05-13-2011, 09:15 PM   #9
fastturtle
Great to hear, so the 700 is next?
Old 05-13-2011, 09:27 PM   #10
janol
S
Tell us why it is better, I have the exact same set up waiting to be built, but my FB helis are still flying fine, what is the main difference?
janol is offline        Reply With Quote
Old 05-13-2011, 09:57 PM   #11
superjoe83
for one there are only 4 links above the swash compared to a ton on a flybar head, which means less things to preflight and replace when they get worn out, FBL heads generally have less slop, or at least less places for slop to develop, they look more like a real heli.
I didn't get into flight characteristics because that is really up to the person flying to decide how they like it, FBL or not
T-Rex 450PRO V2, T-Rex 700E V2, T-Rex 500EFL Pro ICE100 Vertigo motor T-Rex 550 FBL BeastX, KDE/Neu, ICE100
superjoe83 is offline        Reply With Quote
Old 05-13-2011, 10:55 PM   #12
smaze17
Yup - so much easier to put together and less to break too
I still have a FB 700e and 550e. The way the FBL flys is quite a bit different....just so crisp and rock solid. Felt even more stable than any of my FB helis...absolutely love it
S
Old 05-14-2011, 09:17 AM   #13
janol
OK, that is what I'm looking for, how it flys compared to FB. I know the benefits of less parts, I could care less what it looks like.
Better in the wind? Tracks straight through loops?
Old 05-14-2011, 12:39 PM   #14
smaze17
Way better in the wind. I haven't tried any loops but the roll rate is way quicker than a FB bird. Rolls fast and you don't really lose any altitude since the rate is so quick.
Love it man and so will you
S
Old 05-14-2011, 12:53 PM   #15
Brad_M
Ya the pros, better in wind and tracks better through flips, rolls, piros and combinations them. The one big con is crashing can take out servos way easier. Still it feels so much more locked in that I don't care and never going back to FB.
Brad_M is offline        Reply With Quote
