Old 05-13-2011, 08:42 PM   #1
PowerStroke
Default *UPDATE* HELP with build please!
Just got my 500esp in this week and started the build today. Already ran into a issue installing the flybar. When I put it thru the rotor housing the rotor housing became stiff. It still moves but not freely. I made a video to help explain. I removed the flybar cage for the video. Is this a big problem or continue with the build?
PowerStroke is offline        Reply With Quote
Old 05-13-2011, 08:58 PM   #2
Mike2112
Looks OK. Can't feel it from here, but it will loosen up fine in flight I bet. How tight is it really? Will a small weight move it? or is it really binding?
Hirobo Evo .50/Futaba 9C/OS 50 Hyper & Hatori/Radix/GV1/GY401&9254/9252s/Arizona Heli Canopy
Trex 500 FBL/Futaba 8FGS/CGY750/CC ICE 75 & Scorp 1400 16T/Radix/9650s/9256
Trex 450 Pro/Futaba 8FGS/450M 14T/TP Blades/ 3156s/ Futaba GY520&9257
Mike2112 is offline        Reply With Quote
Old 05-13-2011, 09:03 PM   #3
PowerStroke
It doesnt take much pressure to move it. Just concerned me because I thoguht it was supposed to be really loose. Like you said it will probably loosen up.
Blade SR / Blade 400 / TREX 450 Sport
Old 05-13-2011, 09:27 PM   #4
memosteve
Looks fine...
memosteve is offline        Reply With Quote
Old 05-13-2011, 09:46 PM   #5
DKS_ONE
I'm no master for sure, but when you had the camera up close with the flybar in place moving the rotor head back and forth, I could see the flybar spinning/rotating. Looks like it's touching on one side of the rotor head. Are the mounts for the flybar seesaw in right IE: correct number of washers on each side? If so, then likely it'll wear in, but I would double check to make sure the seesaw is centered correctly on the rotor head. I don't disagree with above, it doesn't look bad, but when you secure the flybar and prevent it from rotating, it'll probably be just a bit worse even. So, just make sure seesaw is centered. I don't see it causing you flight issues, but why wonder right?
Danno
Fusion 50, 600 conversion, 600mx motor, CC 80HV ESC with cap pack, Jolly Bee canopy
UMX Carbon Cub SS
DX8
DKS_ONE is offline        Reply With Quote
Old 05-13-2011, 11:44 PM   #6
PowerStroke
Thanks for the help!
Old 05-13-2011, 11:52 PM   #7
Discman
Make sure not to get any Loctite in the bearings. That could cause binding.
Fly'n when the wind aint blo'n
T-Rex 700e F3C, T-Rex 450 Pro Beast, Mini Protos Beast, Gaui H255 Beast, mCP X, mSR
Discman is offline        Reply With Quote
Old 05-13-2011, 11:58 PM   #8
Richard F.
didnt it look like the flybar was hard to push in? is the flybar bent at all? did you roll it on some glass?
Richard F. is offline        Reply With Quote
Old 05-14-2011, 07:45 AM   #9
lankey
I had the same issue but probably worse than that. Turned out to be some poor tolerances in the seesaw which a replacement fixed!
450 PRO, 500 ESP
Due to economic circumstances, the light at the end of the tunnel has been turned off until further notice.
lankey is offline        Reply With Quote
Old 05-14-2011, 09:46 AM   #10
bad007
The flybar has to be hitting the inside of the head and one of the two has a problem.
bad007 is offline        Reply With Quote
Old 05-14-2011, 10:24 AM   #11
memosteve
I just checked mine... It's totally smooth and free, so I'll recant my previous statement and go with something is binding slightly.
Look and see if the flybar is hitting the side of the hub.
Old 05-14-2011, 06:26 PM   #12
PowerStroke
There is no doubt that it is hitting inside the hub. I just didn't know if it will affect flight. It moves but with a slight resistance. The flybar is not bent. I suspect that the seesaw if slightly out of alignment cause it to contact inside the hub.
Old 05-14-2011, 06:54 PM   #13
bad007
Affect flight? Correct it or suffer from vibes and tracking issues from the head being out of ballance. Find out which part is defective and replace it. The build is no go like that.
Old 05-15-2011, 10:21 AM   #14
Mateyhv
Exactly, have a look at the bar passing through the head. It must be hitting somewhere. If so try to find if the flybar is bent/the hole in the head is offset/the seesaw have some problem so the flybar could not pass through the center of the hole.
If the bar is touching somewhere it may solve in a couple of flights but you are correct assuming the flybar should move freely, so better check that point again.
Mateyhv is offline        Reply With Quote
Old 05-15-2011, 06:57 PM   #15
PowerStroke
Did you contact Align for the replacement?
Old 05-16-2011, 02:16 AM   #16
lankey
I would have done mate, but the kit was bought from HK and not worth the hassle of returning. One of the pitfalls of buying cheap from the far east.
As soon as that seesaw was screwed down onto the block I knew there was an issue. Double checked all bearings were seated etc. To the OP, I suggest you strip the head back to the seesaw and check for smooth operation.
End of the day Align kits are pretty high volume, so the odd QC issue is likely.... had quite a few over the years, and if I buy local the offending parts get shipped back for replacement.
450 PRO, 500 ESP
Old 05-16-2011, 06:46 AM   #17
tomra
You could try to rotate the seesaw 180˚ degrees axial to the main shaft. Also roll the flybar on a flat surface. Most of mine has been slightly bent but not more than what can be straightned by hand.
tomra is offline        Reply With Quote
Old 05-20-2011, 11:01 PM   #18
PowerStroke
Default UPDATE! FIXED
Seesaw was the problem, I received the new seesaw today, it works perfect now.
Thanks for help / suggestions.
Old 05-21-2011, 02:30 AM   #19
lankey
Glad it's sorted now mate.
450 PRO, 500 ESP
