Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > Outrage RC > Outrage 550
Outrage 550 Outrage 550 Helicopter Factory Support Forum
Old 05-14-2011, 10:25 AM   #1
txbonds
Default spindle shaft difference?
Are these the same part with different numbers? I have one of each in front of me and they look identical.
http://helidirect.com/r50n5758-outra...is-p-11888.hdx
http://helidirect.com/r50n914ss-outr...on-p-14043.hdx
One says for flybarless, but in real life I can't spot a difference. Anyone know?
txbonds is offline        Reply With Quote
Old 05-14-2011, 11:34 AM   #2
rmalt
Im not 100% but I think that the FBL version is just a larger diameter shaft than the regular one.
Pulse XT 60 Saito 100
~KBDD Team Pilot~
rmalt is offline        Reply With Quote
Old 05-14-2011, 08:57 PM   #3
pctomlin
Those spindle shafts will be identical, they should both be 8mmX93mm. The O550 spindle shafts are 8mmX76.6mm. The V50, Fusion 50 FB/FBL spindles are what you use in the O550 FBL head which is the same as the Velo. Have I rambled enough.
I should have just said "Yes".
Paul
Agile 5.5 - Quantum 4125-1100, Ice 100, Ikon FBL / Outrage 550 - HK4020-1390, Edge 120, iKon FBL
Rave Ballistic FSO - HKIII 4035-560, Ice2 HV160, iKon FBL / Protos Max V2 - MSH 4530-500, Edge HV160, Brain FBL
pctomlin is offline        Reply With Quote
Old 05-15-2011, 03:28 PM   #4
Volcano
The flybarless head uses v50 grips and spindle. I got confused for awhile on my used bird because the flybarred head on it also has an upgraded spindle and grips.
Volcano is offline        Reply With Quote
Old 05-16-2011, 10:07 PM   #5
lazor 22
If they are the same then why the price difference?
Lincoln
#HIGHONHELIS ):>
Pull Hard
RCHO Flying Field, Knightdale NC
lazor 22 is offline        Reply With Quote
Old 05-16-2011, 10:15 PM   #6
pctomlin
Look at the price difference for the O550 gyro tray and a V50 gyro tray. Exact same part.
Paul
Old 05-16-2011, 11:32 PM   #7
Volcano
I edited this post, keep the prices low on the 550 ands shhhh. Or else theyll mark it up, not the other way around.
Old 05-17-2011, 04:12 AM   #8
txbonds
Neither of these is marked as a 550 part though. These are marked both for the Velocity 50, it's just that one says flybarless and one doesn't.
Does the flybarred and flybarless fusion/velocity use the same spindle? I can check them with calipers, but I hate to open the packs just for that as I have them on my spare parts pegboard.
