Go Back   HeliFreak > R/C Helicopter Support > Scale Helicopters
Scale Helicopters Discussions About Scale Helis, compatibility and and projects
Old 05-17-2011, 10:23 AM   #1
gixxernoob
Default Installing a Scale Body on a Trex 500
Anybody have experience on installing a scale body on the Trex 500 i.e. Align, Fusono, etc.? I'm concerned if the scale body would have enough clearance for a servo that's mounted on the boom. Pics, comments, etc. are appreciated
I LIVE FOR THIS!
gixxernoob is offline        Reply With Quote
Old 05-17-2011, 10:53 AM   #2
Patriek
Hi gixxernoob,
What fuselages are you looking at? Most will fit (may be minor modelling involved)
-Patriek
Patriek is offline        Reply With Quote
Old 05-17-2011, 11:55 AM   #3
gixxernoob
I'm looking at MD500 or EC-135 by fusono.
I LIVE FOR THIS!
Old 05-17-2011, 06:16 PM   #4
Hank79
You will need to twist the rudder servo to around twenty five- thirty degree's and bring it in closer to the rear tail gear box on the Hughes with Trex 500 mechanics..... It's a bit of test fitting but does work.
Also you will need to cut a small slit in the end of the tail for the rudder linkage arm to sit so it does not bind in the fuselage inner boom.
Here is my retired Hughes 500MD
http://m.youtube.com/index?desktop_u...?v=BjRK2wiQbP8
AH-6M gunship/700E mechanics/OF six blade head/four blade tail. http://www.helifreak.com/showthread.php?t=330933
Hank79 is offline        Reply With Quote
Old 05-18-2011, 08:27 AM   #5
gixxernoob
Thanks for the replies! I will try your suggestion
I LIVE FOR THIS!
