Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters > JS TZ-V2 Frenzy
JS TZ-V2 Frenzy JS Models TZ-V2 Frenzy Helicopters Discussion
Old 05-18-2011, 10:32 AM   #1
HGJL2009
Default FBL Head for 90 V2
Has anyone fitted this JS FBL head onto the 90 V2 ?
It say's its for the 50 but will fit a 10 mm Main shaft which the 90 has.
Is it man enough for a 90 ?
Most of the 90 size FBL heads fit a 12 mm main shaft.
Will be using the Futaba CGY unit with S-Bus
http://www.hobbyking.com/hobbyking/s...oduct=10743#12
Many thanks in advance.
HGJL2009 is offline        Reply With Quote
Old 05-18-2011, 08:14 PM   #2
Dingo745
I have one of these http://www.amainhobbies.com/product_...d-Frenzy-90-TT
Still building the heli so haven't flown the FBL yet but it fits ok.
If you didn't know Amain stocks JS models parts and are a good alternative to HK
Dingo745 is offline        Reply With Quote
Old 05-18-2011, 08:29 PM   #3
phantom1500
I read the comments on the amain site for the JS FBL head and they complain that the mixing arms are to short and don't allow enough pitch range.
Look at maybe a trex 600 FBL head, I am thinking of getting a trex 600 swash and FBL head as these are 10mm main shaft units.
review:
JS Frenzy V2 90, OS91HZ-H, CY MP6 pipe...Evo 50, OS37, Hatori Pipe...HK500GT...HK450PRO TT...HK450 V2...Trex450 V2
phantom1500 is offline        Reply With Quote
Old 05-19-2011, 03:16 AM   #4
serpent887
Is it really possible to do this? The 90 blade bolt hole and the root thickness is different so is incompatible with a 600 head blade grip....or am I missing something?
TRex 600N CGY750, TRex 600N 3G, TRex 500 VBar, TT Mini Titan VBar
Flybarless is more
serpent887 is offline        Reply With Quote
Old 05-19-2011, 08:04 AM   #5
Mr Nice Guy
Get the RJX head. It is made for a .90 size bird with a 10mm shaft. I have the 12mm version for my T-Rex 700E conversion and it works great and is tough. http://helidirect.com/flybarless-hea...is-p-13158.hdx
Mr Nice Guy is offline        Reply With Quote
Old 05-19-2011, 03:39 PM   #6
HGJL2009
Default Many Thanks
Many thanks for your replies, Food for thought. May go for the JS 90 head with a trexx 600
swash driver, then all the spares that I hold will suffice any incident !!!! Whichever hardware
I use the electronics will be the new Futaba CGY unit. I have watched with great interest serpent887 trials and tribulations that he has had with different FBL systems, and the ease
of the Futaba unit to setup straight out of the box. I am only a club flyer and the reliability of Futaba appeals to me.
Old 05-20-2011, 10:14 PM   #7
phantom1500
You can get stretched 690mm, 4mmx12mm root blades for the FBL heads
http://www.amainhobbies.com/product_...barless-Blades
Like I say, haven't done but have got my shopping list to this, there may be something I'm missing but I think I have is pretty close now.
