| BeastX FBL System BeastX FBL Flybarless System Software and Hardware Support |
What setup are you using to get the blue light at 6 degrees.
Shorter servo horns or ball links ? I know it is not needed, but preferable. Thanks Rory |
You need to move the ball closer to center of the servo. I think it is a good idea since it's going to be easier on your servos. It will give them better leverage to take the load of a fbl geometry.
Henseleit TDR YGE 120 Kontronic 700-52 Skookum 540 JR 8917hv Futaba Bls-256hv Compass 6hv HW 70hv Stock Motor Skookum 540 Ds-610 Ds-650 Align Trex 700ev2 CC120 750mx Beast X MKS Bls950, Bls980 |
I have my balls on the servo arm according to the 3G FBL manual.
Also in the manual, be sure to change the balls on the inner swash plate ring, to the very short ones(very little to none stand-off balls. just check the 3g manual, and examine the swash plate, you will see the difference...
My tutorials: Trex 250 Carbon Fiber Tail Push Rod http://www.helifreak.com/showthread.php?t=238095 |
