Go Back   HeliFreak > R/C Electronics Support > Castle Creations ESC and Software
Castle Creations ESC and Software Castle Creations ESC Software and Hardware Support
Old 05-20-2011, 03:03 PM   #1
mightyq
Question Castle Speed Controller
How many of you are using EC5 connectors to connect the Castles ESC to the battery(or batteries) and How many using Deans or Ultra Deans? Also, did your ESC fail or go up in smoke?
mightyq is offline        Reply With Quote
Old 05-20-2011, 03:06 PM   #2
dago
Check out my threads on the t-rex 500 forum. Sucks! Joe
dago is offline        Reply With Quote
Old 05-20-2011, 03:44 PM   #3
pctomlin
I use EC5 and EC3 connectors on all my stuff now. These are the easiest connectors to solder that I have come across. No chance to melt the plastic when trying to make the joint. You do have to be careful of the ends during soldering/putting together to not allow them to touch. I always keep one covered to avoid this.
Paul
Agile 5.5 - Quantum 4125-1100, Ice 100, Ikon FBL / Outrage 550 - HK4020-1390, Edge 120, iKon FBL
Rave Ballistic FSO - HKIII 4035-560, Ice2 HV160, iKon FBL / Protos Max V2 - MSH 4530-500, Edge HV160, Brain FBL
pctomlin is offline        Reply With Quote
Old 05-20-2011, 03:46 PM   #4
BaconRaygun
Dean’s ultra... Nope, no problems with CC here, have been using them since 06' with RC cars and since last summer for helis.
EDIT:
You won’t melt deans (originals) if your iron is powerful enough and you use the correct technique... I have not in 13 years.
Definitely tricky soldering 10AWG wire for a soldering noob but with a bit of practice and the right iron it’s absolutely no problem.
Wrong iron and/or wrong technique and you will melt them... and the knock off deans are awful.
~SAB~ Goblin 700 ~Compass~ Warp 360 ~Blade~ mCP X (BL)
AMA# 977012
**Team BOCA Bearings**
BaconRaygun is online now        Reply With Quote
