| BCX/CX2/CX3 Blade (eFlite) CX, CX2 and CX3 Helicopters Information and Help |
I've notice that the outer shaft on a cx2 has 2 holes, one for the CX2. What size/type of scre goes in there? Or is it a pin? Will anyone help me?
Thank you in advance |
#2 | |
The hole is for mounting the lower rotor hub to the outer shaft. The screws are on the lower hub. The one hole is to line up the hub in the correct location and screwed in all the way. The screw opposite the hole on the rotor hub should be snugged up and not over tightened. And remember that the guide pins for the links to the swash go down closest to the swash. Don't ask me how I know.
Team Newb pilot BL mCPx (HP06V2 motor/HP03 tail),130X with HP08 motor,Trex 450 Pro V2 (KDE450XF motor,iKON),Trex 500 ESP (KDE500XF motor, iKON),DX7, AMA# 966513. PM me about mCPX & NanoCPX BL conversions. |
| Tags |
| cx2, outer shaft |
