| 100 Class Electric Helicopters 100 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
Has anyone seen this yet and more important has anyone used it? I was wondering if it was a good idea or too heavy!
http://cgi.ebay.com/Align-T-Rex-100-...item3f0a10a718 |
Anyone?
T-Rex 450SE V2 Copter X 450AE V2 T-Rex 100s Blade CP DX6i |
Did you buy these components?
Gazaur MARS 480 * TT Mini Titan E325 SE * Walkera UFLYS/CB180Z-Pro/CB100 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
I haven't bought them yet. I was wanting to get some kind of input to see if they are worth getting or too heavy for the little bird.
Bought Trex 100 3 weeks ago. My first flying Heli. I built a Kalt Baron 30 in the 80's but never put in radio and engine. Bought and installed metal parts last weekend. I like them. Let me tell you how my heli is set up. Changed tail motor and tail to Nine Eagles Solo Pro setup. Got a new flybar and sanded the inside to make it super smooth. so smooth that when I hold the heli in my hand and I rotate it the flybar wants to stay level. I am using the two washers even with the aluminum head so there is no slop. In the dampener shaft I lubed it so it was super smooth and installed a couple of washers so the blades are firmly on but smooth and precise. Kept control arm on flybar smooth too, you do not want it binding. Adjusted the servo links per the manual to keep the cyclic centered. The info about that on Page 16 in manual Items # 9 &10.
Heli flies beautiful. Hovers nice and easy and I am able to practice my flying with ease and fun. I am finally liking the experience as I do not have to be chasing a heli that will not behave. |
#6 |
Just installed the bling setup and really like it. Not sure if the very small amount of plastic head wobble was from crashes or not since I never checked it right out of the box, but the aluminum head has zero wobble as expected. I have slammed this thing into countless walls for the past month and cannot understand the smack talk it gets from some. Only damage I have obtained is one broken landing skid and pulled out one of the mixing levers a couple times. Located the screw on the tile floor and put it back together. I have found it very durable. Anyway added the bling and a new set of blades since they were bent up real good and it flies beautiful. Also have to mention that one reason I threw these parts on is the tail motor mount acts as a heat sink. Put a drop of CA on it instead of the recomended epoxy and shot of activator to keep the motor from sliding out.
#7 |
Finally got some decent pics of the alu head. Have not installed motor mount yet. Enjoy
#8 |
What does the heli weight after all the aluminium upgrades have been installed? How much is flight time and power reduced by, due to the extra weight?
#9 |
I dont have a scale to weigh it. Flight time is about the same as the other head. Power is ok I have noticed that it seems to be smoother maybe it has more inertia I notice that the blades rotate more freely when I power off. With the plastic parts they just stopped. I think its an improvement especially for the price. I have been flying 10+ flights a day for the last 2 weeks.
#10 |
I sorta thought it might have been smoother too, but I did replace pretty warped blades at the same time. Honestly after you pull the parts out of the container they come in they are so light that you won't even think to weight them. I normally do things like weighing upgraded parts and it never even crossed my mind with these. They look bigger than they actually are. When you opent the case everyone I have shown them too is surprised at how small they are.
#11 |
Omg tail motor mount a pain in the A to put on. Also you need to loctie it to the motor or motor will slip out. But it all looks very nice.
#12 | |
Please provide your impressions. Thx.
#13 | |
I had a Walkera 4#3B and added metal parts and tweeks but in all seriousness, it didn't fly noticeably better. On the bigger helis, 450 and up, I can see the difference in performance with aftermarket parts. But maybe it's nice just to enjoy the micros for what they are.... I think sometimes those of us in this hobby fall to the same thing that golfers and fishermen fall into. "If only I had this new club I could take 12 strokes off my game. "If only I had this lure, I could catch a lot more fish"... IMO
Crash Expert In Training
#14 |
I agree with you Mike lots of hobbies have the small add on "performance enhancement" bits that cost a lot but don't add much in performance in absolute term. I suppose its part of the hobby in a way to seek the ultimate machine ...but one none of us ever achieves!!
#15 | |
Why? Simply... because we can. Isn't that the main idea anyway? |
#16 |
So no other impression and opinions about these metal re-fitting component?
I was thinking to buy them, but it seems that they are totally unuseful. Everyone agree on that? |
#17 |
just stuck them on today
didnt think they would be heavier but they slow the machine down heaps it also makes it more unstable so dont bother im going to have to make a motor mod i think now for more power ;p |
#18 |
I ve used the metal head and tail motot holder on mine. I get the impression that the heli COG is making the Rex unstable, keeps pitching forward. I tried to lengthen the servo links but still to no effect.
could the weight distribution is a factor to suspect? |
#19 |
To anyone using the metal out fitting kit. instruction call for T34 threadlock, i that the red type or green type? Thanks.
Robert To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
