Go Back   HeliFreak > R/C Helicopter Support > KDE Direct Upgrades and Accessories
KDE Direct Upgrades and Accessories KDE Direct Upgrades and Accessories Factory Support Forum
Old 05-25-2011, 08:29 PM   #1
Finless
Team Taco VP
Default Review/Assembly KDE Trex Tail Upgrades
KDE has some new upgrades out which can be a little technical to install. The Trex700 tail control system and the Trex 550/600/700 High Performance tail upgrade.
KDE asked if I would review them and show you all how to install them on your Trex700. No problem! I love KDE stuff
So on with the show. The videos are in 3 parts.
VIDEO LINK -> Part 1 - KDE Trex Tail Disassembly and Assembly of the Upgrade Tail Slider (96 Megs)
VIDEO LINK -> Part 2 - KDE Trex Tail Control Upgrade Assembly (54 Megs)
VIDEO LINK -> Part 3 - KDE Trex550/600/700 Performance Tail Upgrade Assembly (50 Megs)
Enjoy folks!
Bob
"Don't Taco My Pack Dude!"
Old 05-26-2011, 09:18 AM   #2
KDE Direct
Hey Bob,
That was great, thank you for the videos! You did an excellent job explaining all the finer details of the install and noted all the things to watch out for during each step. It's easy to see why you are the leader of RC Helicopter videos, you have the talent.
I'll look into the Bearing Holder upgrade and the internal sleeve. As a quick note, rather than trying to use a Soldering Iron to heat the components, a Heat Gun or Butane Torch is a much easier method to use. The team and I simply use a Heat Gun (a cheap one purchased from a local hardware store used to heat shrink-tubing) to heat the Aluminum housing of the Bearing Holder. Once the Loctite gets to the right temperature, it will liquify and the bearings will pop out quite easily without having to damage the bearings. In a pinch, a Lighter also works well at the field.
Then, you can choose to use "The Greaser" to regrease the original bearings, or toss them aside and use the new ones supplied in the kit.
-- KDE Direct, Inc. --
KDE Direct is offline        Reply With Quote
Old 05-26-2011, 10:35 AM   #3
Finless
Team Taco VP
I used a soldering iron because that is what most people have. I try to show how to do things with the most common tool. I do have a pen torch and yes I do use that myself for this kind of stuff. Just wanted to show people how to do it with something most everyone has. Yes for the slider the lighter also worked as I showed in the vid. Even then getting a tool on the tiny lip of the inner race past the spacer was a bear. But this is true for many things like getting the bearings out of blade grips etc.
FYI folks in the beginning I said I was going to show the boom supports and take them apart. DONT DO IT! They do not come apart. This is why I did not show this at the end like I said I would.
So just FYI there.
Bob
Old 05-26-2011, 04:42 PM   #4
HeliBenj
Hey Bob, thanks for the nice vids.
Similar to the Outrage design which I liked on the Velocity.
Will be interesting to know if you can notice any difference in flight in case you had problems with your tail.
Maybe dumb question, did adding a bunch of bearings and ali and screws far off the CoG affect it or is it too small to make any difference?
Ben
Goblin 500 IKON w/ gov, Quantum 4115-1200, Hitec 5245, BLS251
DX8, RF6
HeliBenj is offline        Reply With Quote
Old 05-26-2011, 05:15 PM   #5
Ozz58
Do they make the tail control system upgrade for the 600 or just the 700?
Looks like a nice and needed upgrade.
Craig
T-Rex 600N | T-Rex 500 ESP | T-Rex 500 GF | T-Rex 250 (Love this little bird) | 15 year old Shuttle ZXX
Ozz58 is online now        Reply With Quote
Old 05-26-2011, 06:30 PM   #6
philipfrank
if they make one for the 600, it should also fit the mikado.
the stock 600 slider works on the logo.
i'll take one.
philipfrank is offline        Reply With Quote
Old 05-26-2011, 07:18 PM   #7
Finless
Team Taco VP
I don't think on a 700 there will be any noticeable difference in CoG honestly. Haven't flown it yet but I bet I wont notice much in that area. I think this tail upgrade will simply be easier on the servo and more reliable as far as wear and building slop. My bell crank was getting pretty loose on the slider ball which is a problem with Aligns design over time. With this upgrade I don't think this will ever build slop unless the bearings wear out.
Bob
Old 05-27-2011, 08:42 PM   #8
Dogdocphil
Thanks for the Vids! I am a BIG fan of KDE's stuff and I will be getting this upgrade soon! Hello Patrick!
Dogdocphil is offline        Reply With Quote
Old 06-05-2011, 06:50 PM   #9
insane99
Default kde upgrade
just pressed the order button from HeliDirect. now for the wait. Postal strike may hold things up a bit
Rex 550 FBL , CC BeC Pro , CC Ice 100 , KDE tail V2 , Divorced and BROKE !
insane99 is offline        Reply With Quote
Old 06-07-2011, 10:20 PM   #10
Hellsiege
I have a flybar'd 550 - wondering if this upgrade would get rid of a wag I've been chasing since built? I do have a decent ammount of slop and the wag seems to be there no matter the gain / RPM and then goes away for brief periods only to return randomly? Order the upgrade?
Steve
Hellsiege is offline        Reply With Quote
Old 06-11-2011, 06:50 AM   #11
Justin Stuart
The bellcrank/pitch slider seen in the video is for the 700 and not for the 550/600, right?
Avant RC
Scorpion Power Systems
ThunderPower RC
Kontronik Drives
Justin Stuart is offline        Reply With Quote
Old 07-27-2011, 06:35 PM   #12
KDE Direct
Hey Justin,
Yes, the design is only compatible with the 700 series helicopters at the moment. Due to the size difference between the slider on the 700 and 550/600 series, they are not compatible with the same upgrade design.
Also, Finless brought up good points on the install, so I want to let customers know we are listening to these and are working on addressing any difficulties with the install. I'll make sure and keep everyone posted on the progress for future production releases.
Old 07-28-2011, 03:27 PM   #13
Ozz58
Originally Posted by kegerator View Post
Hey Justin,
Are you planning on making this upgrade for the 600 series?
Craig
Old 08-22-2011, 02:11 PM   #14
KDE Direct
The "V2" version has been released, which now includes the internal Bearing Holder Collar and a few other modifications to drastically simplify the install and performance of the upgrade. Thank you Finless for your constructive criticism in the video and to customers who sent us great feedback, the new V2 design is an improvement that was worth the time and effort.
I've attached the new Installation Diagram to show the changes for installation.
Old 09-04-2011, 11:17 AM   #15
Scootz74
Default Tail lovin' action...
KDE Team, Thanks for the Excellent and, might I say, Lightning fast customer service when I had a damaged component in the V1 kit and for the technical help your team gave when Installing it on my lil' machine. (Finless, you and I must have gotten the kit at the same time, so your videos were not there for me to watch, sadly.)
I have since flown the machine and the "Flying Roto-Tiller" has not only lost its slop in the linkages, but the best part is the complete and utter loss of tail wag that I was having from the stock set-up.
Thanks KDE.
Finless and the Heli-Freak Team, The videos are excellent and straight to the point (in detail) and in a very layman's description for ease of understanding. Thanks for your hard work (Like something that you love to do is considered hard work...But...) and effort to help all of us that strive to enjoy this hobby to its fullest.
Thanks Finless.
Have one more thing for the KDE team.
What do you think the difficulty would be to change a few of the components to "flip" the rotor from the right side to the left side for scale fuselage applications? (i.e. Bell 222 or Bell 430) I don't think that I would trust anything less on a high end project than the quality that I have seen from your crew.
T. Scott "Scootz"
Every time I think I'm good at this hover thing, Gravity gets the best of me...
Quit yer cry'n and fly.
Align T-Rex 700N, HK450 PRO TT, HK450 PRO Belt, Blade MSR, Spektrum DX7se, Spektrum DX8
Scootz74 is offline        Reply With Quote
Old 09-14-2011, 02:42 PM   #16
KDE Direct
Old 09-14-2011, 03:24 PM   #17
Finless
Team Taco VP
Brain fart? What happend?
Bob
Old 09-14-2011, 04:57 PM   #18
KDE Direct
Sorry, wanted to correct this before posting again...
Hey Guys -
I was just helping a customer who had a distinct tail wag that he could not get rid of. He had installed the AT700-PTC-V2 design on his brand-new TREX 700E V2 3GX to try and get rid of the tail wag, and no luck. We tried replacing the tail servo, changing settings in the 3GX, and all of these wouldn’t cure the issue…spent a few days and many e-mails looking into this...
Well, turns out there is a design-flaw in the new ALIGN V2 Metal Tail Rotor Holder assembly released separately and with the new "V2" 3GX kits. In the new stock design, a dual-radial bearing is added to further support the tail (similar to the PTU upgrade, just different bearing ordering). What the designers missed is a critical spacer that goes between the outer radial-bearing and thrust-bearing to prevent lockups. Similar to the Main Rotor Assembly, this spacer is critical to prevent the inner-race and the outer-race of the radial bearing from contacting the thrust-bearing washer at the same time. Without the spacer, the assembly may feel smooth on the bench, but once the axial loads are imparted by the centrifugal force of the tail blades, it will lock up in flight and cause severe tail wag issues. Essentially, both the inner and outer thrust-bearing races are locked, and excessive forces are needed to turn the assembly in flight - producing the problematic tail wag.
For the customer, he installed an older ALIGN V1 Metal Tail Rotor Holder he had available with the KDE Direct PTC/PTU-V2 upgrade assembly and the wag immediately disappeared.
Name:	Trex 700E V2 3GX Manual_Page_15.jpg
Old 09-15-2011, 11:14 PM   #19
smaze17
Hello kegerator!
What if I'm using this assembly:
http://www.ebay.com/itm/270814908870...ht_2960wt_1037
Still have the problem?
Thx
S
Compass 7HV / iKON / CC ICE2 80HV / Align 700MX / Edge 693FBL
Trex 700 Pro / iKON / CC EDGE 120HV / Align 800MX / 3G 700's
KDE Blinged Blade 130X
smaze17 is offline        Reply With Quote
Old 09-16-2011, 09:59 AM   #20
Sirolf
Originally Posted by smaze17 View Post
Hello kegerator!
Thx
S
Same one i've ordered, these should be OK
Align Trex 450Pro - BeastX - Scorp-8
Align Trex 600NSP DFC - BeastX - 91HZ
Align Trex 700E DFC - BeastX - 700MX 6+7x1.25
Sirolf is offline        Reply With Quote
