Go Back   HeliFreak > R/C Electronics Support > Castle Creations ESC and Software
Castle Creations ESC and Software Castle Creations ESC Software and Hardware Support
Old 05-26-2011, 11:30 AM   #1
ramsdellcp
Default Castle HV 120 settings resulting in pulsing throttle
Hey guys,
I followed the settings for a 700 mx motor per castle guidelines found here:
http://www.castlecreations.com/suppo...00MX-510KV.pdf
The problem I am having is that in any flight mode the motor seems to pulse (throttle up, then down a little, then back up ect), i am spooling up with no blades on atm, is this normal for castle governers?
ramsdellcp is offline        Reply With Quote
Old 05-26-2011, 11:43 AM   #2
gothicbunny
Sounds like a low voltage cutoff.
gothicbunny is offline        Reply With Quote
Old 05-26-2011, 12:00 PM   #3
helidude71
With firmware v3.27?
TSH Gaui X5 FES, Spirit, S.Bus, HW100A V3
TSH Gaui X3, Spirit, 6S, S.Bus, HW50A V3
Futaba T7C (I admit, also a Spektrum DX8 and some planks.) ;-)
Phoenix R/C v5
helidude71 is offline        Reply With Quote
Old 05-26-2011, 12:05 PM   #4
Chris_M
LVC would shut it down completely. Are you running gov or fixed endpoints?
Chris_M is offline        Reply With Quote
Old 05-26-2011, 01:04 PM   #5
ramsdellcp
V3.27
Running gov with fixed rpm setting
Old 05-26-2011, 01:30 PM   #6
BaconRaygun
Originally Posted by ramsdellcp View Post
Hey guys,
The problem may be the fact that you are spooling up with no blades.
Have you checked the logs?
You sure you don't have anything binding or exerting drag on to the drive system? You may be bouncing off the current limiter. A log would really help.
~SAB~ Goblin 700 ~Compass~ Warp 360 ~Blade~ mCP X (BL)
AMA# 977012
**Team BOCA Bearings**
BaconRaygun is online now        Reply With Quote
Old 05-26-2011, 04:10 PM   #7
helidude71
I think I read a thread on rcgroups where CC suggested to go back to V3.20
Maybe you can try it?
Phoenix R/C v5
Old 05-26-2011, 04:18 PM   #8
WillJames
Registered User
Are you in GOV mode? If so gain possibly to high?
What does it do with the blades on it?
William James
WillJames is offline        Reply With Quote
Old 05-26-2011, 04:24 PM   #9
f22warzone
incorrect, if in soft cut off it would go into lvc and cut power until the batteries rose back up and then would give power to bring rpm up, then cut power as it would be drawing amps, then..... you would get this oscillation if a your batteries are really really really weak as your probably only drawing 3a if its just the motor and 14a with every thing but blades, or b you are just in storage charge batteries and they have just enough to meet lvc but not enough to keep it above.
TRex-800E /Scorp 5035-478 5+5YY 1.8mm/VBar Blue Full 5.2Pro /CC Hv160/WR-Herc Super BEC/RJX 810mm 3D /RotoTech 115 + QuickUk Tail/ Hitec 7940th HV/TP 5000 65c
f22warzone is offline        Reply With Quote
Old 05-26-2011, 04:42 PM   #10
flyinghigh450
Buy this and i'll set it up for you http://www.readyheli.com/PHXLINK-Cas...t_p_35775.html ..
Team Align
flyinghigh450 is offline        Reply With Quote
Old 05-26-2011, 04:43 PM   #11
flyinghigh450
Team Align
Old 05-26-2011, 06:10 PM   #12
ramsdellcp
I picked up a castle link this morning, one of my issues was the esc was not saving settings using the beeping/tx method. Using the link solved this as I am now able to save settings to the esc.
Alright so I have saved the files of my setup, one is for fixed point throttle and the other is for the governor settings I'm using. - these are the settings direct from the cc website. please let me know if something needs changing.
In both type of throttle settings I get the same pulsating. It's like it can't pass a certain threshold, I know the head should be spinning much much faster based on comparisons on my 550e headspeed @ 70% throttle.
I've also video taped it so you guys can hear the sounds:
Doesn't matter if I flip to idle 1 or 2, the headspeed never changes and continues on with this pulsating thing.
When I try spooling up with blades on, it can't even get off the ground at 100% throttle, just barely enough head speed to tip the skids a little bit. The headspeed looks like it is around 800 maxed out, yes 800, not 1800.
Old 05-26-2011, 06:18 PM   #13
ramsdellcp
Here is the log. The last flight on the log is the spool up shown in the video above
Old 05-26-2011, 08:38 PM   #14
f22warzone
....... your pulling a constant 280A.
your esc is shutting down because of over current, it even tells you that in the first 6 cycles
the odd thing is tho that your batteries are putting out a constant voltage, as in under a 280 load they would be dropping 5-6v but their staying constant...... so looks like your esc is messed up as also it stays at about 90'f which would not be possible pulling the 14kW your says it is
so bottom line, you have a bad current sensor and its peged at 280A making the esc think it needs to save its self so it cuts the motor and you see pulsing.
Old 05-26-2011, 08:45 PM   #15
ramsdellcp
that's why I posted, thanks.
Old 05-26-2011, 08:46 PM   #16
f22warzone
sorry that was mean, bad day at work : ) ..... but still glad i could help you out..... chances are if you tell CC that they will offer to replace it right away.
Old 05-26-2011, 09:00 PM   #17
ramsdellcp
do you think using version 3.27 would have anything to do with this? should I try rolling back to a earlier version?
Old 05-26-2011, 09:19 PM   #18
f22warzone
You can try but chances are it wont do any thing, have seen this before. its a bad pick up sensor or something like that.
Old 05-26-2011, 09:22 PM   #19
ramsdellcp
alright, thanks for the heads up. at least I know what the problem is now. should've gotten the kontronic from the get go. lesson learned
Old 05-26-2011, 11:59 PM   #20
johnbs8
ramsdellcp, if you bought the ESC from the hobbie store, you could probably take it back to them? exchange??
TT E700, TT X50, Compass Warp Mikado Logo 550sx
johnbs8 is offline        Reply With Quote
