Old 05-29-2011, 12:23 PM   #1
daneger21
Default HYPERION 240's ARE BACK IN STOCK...look here!
Im sure they are gonna go quick. i just ordered 3 batterys and some micro deans to go along with them. figured i put out the word for others...
3 batterys, enough deans to do all 3 batterys, the heli, and make 3 charging adaptors, then shipped to my door was $36.
$6.99/each
http://www.readyheli.com/HP25C02401S...X_p_38286.html
daneger21 is offline        Reply With Quote
Old 05-29-2011, 03:01 PM   #2
Gregor99
Most are using the bare cells. Lighter, cheaper ($3.99) and fit better in the Dylwad battery mount.
http://www.allerc.com/hyperion-g3-cx...ll-p-4500.html
Gregor99 is offline        Reply With Quote
Old 05-29-2011, 07:19 PM   #3
daneger21
Those are back ordered, the ones I found are not. IMO i don't care what others are using cause these are in stock where everywhere else is not. These ended up being about the same price as stock eflite batteries. And that's converted to deans with extra charging adapters, so I could have saved atleast $3 and not made those. So next time I get some I wont have to buy extra deans for the adapters.
Just sayin...
Old 05-29-2011, 09:11 PM   #4
MaddMark
Default Hyperion 240mah 2s
a little more work , but , I bought 2s hyperions and split them to bare 1s packs.
about 4.95 each from allerc.com.
Worked out awsome.
MaddMark is offline        Reply With Quote
Old 05-31-2011, 02:06 PM   #5
Spot 242
Does these lipos need the ends converted to plug into the standard mcpx?
Spot 242 is offline        Reply With Quote
Old 05-31-2011, 05:45 PM   #6
Gregor99
Yes. See the note the RH web page:
It is NOT the same type of plug that comes stock on the MCP X.
Also because the wire connecting wire is so small its be good to replace that while you at it. Then remove the unneeded blue covering to save weight. I know many will go the Micro Deans route. But since the Dean's weigh 3 times the stock connector and allow you to short to batteries together, I'm choosing to pass on those.
